29653 Discussions
Passing string from Visual CPP to Visual Fortran
mch7918
Can some one tell me how to pass a char array from visual c++ code to a fortran subroutine.
I tried below code, it doesn't work for me..
My CPP code:
extern "C" {void Routine1(char* param1, char* param2);}
Method:
char param1[]="c:/text1.txt";
char param2[]="c:/text2.txt" ;
Routine1(param1,param2);
Fortran Code:
SUBROUTINE Routine1(param1, param2)
!DEC$ ATTRIBUTES DLLEXPORT::Routine1
CHARACTER(100) :: Routine1,Routine2
!Some logic
END
TimP
Unfortunately, you have several options, with more or less system dependence involved. The compiler docs should be your friend. If you don't want to deal with additional hidden length arguments, you can USE iso_c_binding and follow any of the documents about character string/arrays with ISO C interop, even those not specific to Intel Fortran. In this case, the terminating \0 from the C side will appear as a character element ACHAR(0) on the Fortran side.
