29286 Discussions
Passing two-dimensional dynamic array from C to Fortran
Intel_C_Intel
Hello
I have some trouble. I want to pass two-dimensional dynamic array from VC++ to IVCs DLL. My DLL subroutine:
Code:
Subroutine DecompS( N, A, cond, IPvt, MatrixType )
	!DEC$ ATTRIBUTES DLLEXPORT, C, DECORATE, ALIAS : 'DecompS' :: DecompS
	!DEC$ ATTRIBUTES REFERENCE :: cond
	integer, parameter :: R_ = Single_
	integer(I_), intent(in) :: N, MatrixType
	real(R_), intent(inout) :: A(N, N)
	integer(I_), intent(out) :: IPvt(N)
	real(R_), intent(out) :: cond
	print *, A
end subroutine DecompS
In VC++ I declare:
Code:
extern "C" __declspec(dllimport) void DecompS( int N, float **A, float *cond,
	int *IPvt, int MatrixType );
int _tmain(int argc, _TCHAR* argv[])
	int N;
	int i, j;
	int *IndexPivot;
	float **A;
	float cond;
	N = 3;
	IndexPivot = new int;
	A = new float*;
	for( i = 0; i < N; i ++ ) {
		A = new float;
	A[0][0] = 10;
	A[0][1] = -7;
	A[0][2] = 0;
	A[1][0] = -3;
	A[1][1] = 2;
	A[1][2] = 6;
	A[2][0] = 5;
	A[2][1] = -1;
	A[2][2] = 5;
		for( j = 0; j < N; j ++ )
            printf( "%5.0f", A );
		printf( "
	DecompS( N, A, &cond, IndexPivot, 1 );
DecompS prints another numbers. If I write in VC++:
Code:
extern "C" __declspec(dllimport) void DecompS( int N, float *A, float *cond,
DecompS( N, *A, &cond, IndexPivot, 1 );
DecompS prints first string Ok, thats because C++ is row-ordered, but next numbers from nowhere, they are absolutely another. In memory they must be together. Whats going on there?
Jugoslav_Dujic
Valued Contributor II
Well, you described it yourself in a previous thread -- C (generally) doesn't have dynamic 2D arrays, but only arrays of pointers to 1D arrays. And that's not the same as Fortran 2D array.
So, you either have to
- have a 1D array on C side, which you have to manipulate with address mathematics rather than [][], or
- write a more appropriate Fortran structure, which is a pain. That should be like:
type t_row
integer(int_ptr_kind(prow)):: pRow
end type t_row
Subroutine DecompS( N, A, ...)
type(t_row):: A(*)
real(R_):: row(N); pointer(pRow, row) !A "cray" pointer
do i=1, N
pRow = A(i)%pRow
do j=1,N
row(N) = whatever
end do
end do
(Replace "row" with "column" depending on which is easier to read for you).
Neither solution is particularly appealing though. To me, it looks best to define a class/struct in C++ holding a 2-D array in 1-D form with dimension information, then define operator [] for it. In that way, you will get both C++ and Fortran code "looking like" you work with a 2-D array all the time.
Jugoslav
Intel_C_Intel
Thank you, Jugoslav. I preferred first method. Second requires serious changes in Fortran program thats real pain, for it. But the last your approach is the most professional. But it seems to have some strange indexation: Matrix[Index(i, j)]. Index is a structure {int i, int j}. We know that impossible overload double index like in sharp. So this is what I get:
Code:
	int IPvt[], int MatrixType );
int _tmain(int argc, _TCHAR* argv[]) {
	int N;
	int i, j;
	int *IndexPivot;
	float *A;
	float cond;
	N = 3;
	A = new float[N * N];
	A[0*N + 0] = 10;
	A[0*N + 1] = -7;
	A[0*N + 2] = 0;
	A[1*N + 0] = -3;
	A[1*N + 1] = 2;
	A[1*N + 2] = 6;
	A[2*N + 0] = 5;
	A[2*N + 1] = -1;
	A[2*N + 2] = 5;
            printf( "%5.0f", A[i*N + j] );
		printf( "
	return 0;
It works but looks a little bit baldy for C++. Next probably stepshould beoperator [] and class Matrix: A[Index(i, j)]. But I wouldnt do this too say and probably slower. "That's C++", what can I say more? Anyway, I get what I want. Thanks again.
Jugoslav_Dujic
Shouldn't be too difficult. My C++ is rusty, but since I'm curious too, here's a quick sample:
#include "stdio.h"
struct Matrix
float* pf;
int nRows;
int nCols;
float* operator [] (int iRow)
{return (pf + iRow*nCols);};
Matrix(int iRows, int iCols)
nRows = iRows;
nCols = iCols;
pf = new float[nRows*nCols];
~Matrix()
{delete[] pf;};
int main(void)
Matrix A(6,5);
for (int i=0;i<6;i++)
for (int j=0;j<5;j++)
A = float(100*i + j+1);
for (i=0;i<6;i++)
for (int j=0;j<5;j++) printf("(%10.1f )", A);
printf (" ");
return 1;
Jugoslav
Message Edited by JugoslavDujic on 08-24-2005 09:46 AM
Jugoslav_Dujic
P.S. The code above works (and does not produce any memory problems), but please carefully check what I wrote regarding rows vs. columns -- it's quite possible that I mixed them up so the poor reader gets confused. I can correctly process that kind of stuff only after very careful thinking, but I don't feel like doing it right now :-).
Jugoslav
Intel_C_Intel
Thanks fro approach, Jugoslav.
Cool. I would never guessed. Actually thats because I do not understand why does double operator A work. Theoretically its a (pf + iRows*nCols)+jRows*nCols but works like a (pf + iRows*nCols)+jRows. It seems that second operator means just + for address. This useful and means that with tree-dimensional array problems may happen.
But it isnt important for me now. Ive some trouble with this code:
Code:
#include "stdafx.h"
struct Matrix {
	float* pf;
	int nRows;
	int nCols;
	float* operator []( int iRow ) {
		return( pf + iRow*nCols );
	Matrix() {
	Matrix( int iRows, int iCols ) {
		nRows = iRows;
		nCols = iCols;
		pf = new float[nRows * nCols];
	~Matrix() {
		delete [] pf;
	Matrix A;
	// Matrix A = Matrix(1, 2);
	A = Matrix(6, 5);
	for( int i = 0; i < 6; i ++ )
		for( int j = 0; j < 5; j ++ )
			A = float( ( i + 1)*100 + j + 1 );
	for( i = 0; i < 6; i ++ ) {
			printf( "(%10.1f  )", A );
		printf( "
	getchar();
	return 0;
I added default constructor and default Matrix A declaration. Program throws exception. Somethings going on with memory. The same will be if uncom-ment string and comment Matrix A. Do you have any ideas?
Jugoslav_Dujic
As I said, I'm not a C++ expert :-). I played a bit with the code and concluded that you mustn't do:
A = Matrix(6, 5);
When I step into the constructor in the debugger, it says:
this CXX0069: Error: variable needs stack frame
i.e. the constructor is called for a non-existing object. Instead, you have to give it a frame somehow:
int main(void)
Matrix *A;
A = new Matrix(6,5);
(*A) = float(100*i + j+1);
for (i=0;i<6;i++)
for (int j=0;j<5;j++) printf("(%10.1f )", (*A));
printf (" ");
return 0;
In this way, the object is constructed on the heap.
Jugoslav
Intel_C_Intel
Right yours. I forgot that struct is not in a heap. Now its looking and working good. Thanks for help, Jugoslav.
