29363 Discussions
Peculiarity of /fpconstant between release and debug in calls
nvaneck
I tell the compier to extend all single precision constants to double precicison. When compiling with debug and telling the compiler to check interfaces, I get no warnings. When compiling in relese mode, I get warnings, e.g., for
CALL SUB(0.0)
END
SUBROUTINE SUB(F)
REAL(8) F,D
D=F
END
Not a big deal as I had only 4 instances and changed them to sue 0D0 to be safe but it was surprising.
Normally, I don't have check interfaces on for release mode, so I hadn't noticed it before. The real question is, did the compiler extend the constants in other areas for release and debug mode, and did it in fact do so for the call?
subroutine
More likely is that when you changed the default real kind to double, you did so only for the Debug configuration. You have to explicitly select "All configurations" to get the change applied to both.
nvaneck
Not true, it's been this way for years. I just changed the warn interfaces. Otherwise, options are the same except for debug stuff. Sounds like a bug to me--I just hope it's a warning bug and not more serious. Easy for you to check with sample included.
mecej4
I cannot see any sample in this thread other than the short program shown in-line in #0.
That one is special since zero has a special representation -- all zero bits in single and double precision. Therefore, an argument or a function value of zero is tolerant to mismatches between REAL*4 and REAL*8 arguments.
nvaneck
Well, that's the smallest example, which you always ask for, to demo the problem. The warn interfacesoption complains when fpconstant is set, but only in release mode. Here's another with a non-zero:
SUBROUTINE TEST
call sub (0.0)call sub (1.2)
end
subroutine sub(f)
real(8) f,d
d=f
end
D:\Projects\MicrOsiris\PGMS\TEST.F90(6): error #6633: The type of the actual argument differs from the type of the dummy argument. [0.0]
D:\Projects\MicrOsiris\PGMS\TEST.F90(7): error #6633: The type of the actual argument differs from the type of the dummy argument. [1.2]
compilation aborted for D:\Projects\MicrOsiris\PGMS\TEST.F90 (code 1)
And yes, fpconstant specified.
These errors do not appear in debug mode.
I can't reproduce this using your example. Please show the build log for the Release build.
nvaneck
This is way to much trouble for what I thought was a heads up on an erroneous error message. It is not a problem for me since the code is correct, and I guess you're sure the fpconstant is correct with the interface warning as well.
------ Build started: Project: MicrOsiris, Configuration: Debug|Win32 ------
Compiling with Intel Visual Fortran Compiler XE 12.1.1.258 [IA-32]...
TEST.F90
Build log written to "file://D:\Projects\MicrOsiris\Debug\BuildLog.htm"
MicrOsiris - 0 error(s), 0 warning(s)
---------------------- Done ----------------------
------ Build started: Project: MicrOsiris, Configuration: Release|Win32 ------
TEST.F90
D:\Projects\MicrOsiris\PGMS\TEST.F90(3): error #6633: The type of the actual argument differs from the type of the dummy argument. [0.0]
D:\Projects\MicrOsiris\PGMS\TEST.F90(4): error #6633: The type of the actual argument differs from the type of the dummy argument. [1.2]
Build log written to "file://D:\Projects\MicrOsiris\Release\BuildLog.htm"
MicrOsiris - 3 error(s), 0 warning(s)
Options for diagostics are
Yes (/warn:declarations)
Yes (/warn:unused)
Yes (/warn:ignore_loc)
Yes (/warn:truncated_source)
Yes (/warn:uncalled)
Yes (/warn:interfaces)
Fortran 2003 (/stand:f03)
Sorry if it's too much trouble, but what you posted is not the build log. I want to see the buildlog.htm in the Release subfolder.
nvaneck
But all I did was compile...
ifort /nologo /O3 /Ob0 /heap-arrays0 /Qipo /I"D:\PROJECTS\MICROSIRIS\INCLUDE" /arch:SSE3 /extend_source:132 /noaltparam /standard-semantics /stand:f03 /Qopenmp-report0 /Qpar-report0 /Qvec-report0 /Qdiag-disable:5268,5142,7416,8290,8291 /warn:declarations /warn:unused /warn:ignore_loc /warn:truncated_source /warn:uncalled /warn:interfaces /Qauto_scalar /fpe:1 /fp:strict /fpconstant /module:"Release/" /object:"Release/" /Fd"Release\vc100.pdb" /check:none /libs:qwin /c /Qvc10 /Qlocation,link,"c:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Projects\MicrOsiris\PGMS\TEST.F90"
call sub (0.0)
call sub (1.2)
IanH
Does your debug build have /real-size:64 ?
Without that I think the error messages are quite valid. I get them here compiling the example in #5 with /warn:all and other debug options.
Oh, now I get it. You misunderstand what /fpconstant does. It does not make single precision constants double precision. What it does is maintain all the digits internally until you assign the value to a double (or quad) precision variable. It does not change the kind of the constant.
The purpose of this option is to maintain compatibility for pre-F90 code that did something like this:
double precision pi
pi = 3.1415926535897
Many F77 compilers, including DEC's, would keep all the digits in its internal conversion, and then convert down on the assignment. Fortran 90 doesn't allow that - the above is a "default real kind" constant and extra digits are thrown away. We gave you /fpconstant to get the old behavior. But it doesn't make such constants double precision when passing as arguments.
nvaneck
For some reason, I can't reply to the "Peculiarity of /fpconstant between release and debug in calls" item....
But I do want to thank Stevefor solving the mystery. It'sstrange the debug version didn't catch it, but I know what I have to do now.
ifort /nologo /debug:full /Od /I"D:PROJECTSMICROSIRISINCLUDE" /arch:SSE3 /noaltparam /standard-semantics /stand:f03 /Qopenmp-report0 /Qpar-report0 /Qvec-report0 /Qdiag-disable:5142,7416,8290,8291,7410,6009,6463,6135 /warn:declarations /warn:unused /warn:ignore_loc /warn:uncalled /warn:interfaces /real_size:64 /Qauto /Qtrapuv /Qzero /fpconstant /module:"Debug/" /object:"Debug/" /Fd"Debugvc100.pdb" /traceback /check:pointer /check:bounds /check:uninit /libs:qwin /dbglibs /Qmkl:sequential /c /Qvc10 /Qlocation,link,"c:Program Files (x86)Microsoft Visual Studio 10.0VC\bin" "D:ProjectsMicrOsirisPGMSTEST.F90"
