Everytime I start a debug session - Intel Fortran 12recompiles the current project - actually it recompiles all projects within the current solution.
How do you stop it from doing this time-consuming compile when I start the debugger?
Try this. Remove all the source files from your project and then re-add them. This is not the normal behavior, but I have seen it.
Didn't work.
It has been doing this since I upgraded to V12.
Every project I have created (about 20) since then, the debugger will trigger a recompile of all projects within the "solution".
My "solutions" typically have a one or more static or DLL libs along with a client project.
When I hit F5, all libs and the client are recompiled.
This really has become very time consuming now as some of my projects are very large.
Hmm. Ok, try this. Open the folder with your .vfproj file in it. Do you see a file with the same name as the project file but with the file type .u2d? If not, in the folder window, select Tools > Options > View. Select "Show hidden files, folders and drives" and click OK. Now you should see it. Delete the .u2d file and reopen Visual Studio.
Are your source files on a network share?
I currently have a solution with two projects - same source files - so the projects are identical - just different project names.
1) I select the "build" option on the second project.
2) Both projects are compiled
3) I deleted the *.u2d file from each project's directory.
4) No breakpoints are set in either project.
5) I hit f5 - both projects are recompiled and the *.u3d files are created again within each project directory.
6) I hit F5 again - with no changes to either project source files - projects are recompiled again.
Summary: Test indicates that deleting th *.u2d file has no effect.
I am not using a network share.
Can you attach a ZIP of the sources so that we can investigate? Might you have any circular module dependencies?
