29277 Discussions
howto: stop recompile when debugger strarts
Terry_Gerald
Everytime I start a debug session - Intel Fortran 12recompiles the current project - actually it recompiles all projects within the current solution.
How do you stop it from doing this time-consuming compile when I start the debugger?
Steven_L_Intel1
Try this. Remove all the source files from your project and then re-add them. This is not the normal behavior, but I have seen it.
Terry_Gerald
Didn't work.
It has been doing this since I upgraded to V12.
Every project I have created (about 20) since then, the debugger will trigger a recompile of all projects within the "solution".
My "solutions" typically have a one or more static or DLL libs along with a client project.
When I hit F5, all libs and the client are recompiled.
This really has become very time consuming now as some of my projects are very large.
Steven_L_Intel1
Hmm. Ok, try this. Open the folder with your .vfproj file in it. Do you see a file with the same name as the project file but with the file type .u2d? If not, in the folder window, select Tools > Options > View. Select "Show hidden files, folders and drives" and click OK. Now you should see it. Delete the .u2d file and reopen Visual Studio.
Are your source files on a network share?
Terry_Gerald
I currently have a solution with two projects - same source files - so the projects are identical - just different project names.
1) I select the "build" option on the second project.
2) Both projects are compiled
3) I deleted the *.u2d file from each project's directory.
4) No breakpoints are set in either project.
5) I hit f5 - both projects are recompiled and the *.u3d files are created again within each project directory.
6) I hit F5 again - with no changes to either project source files - projects are recompiled again.
Summary: Test indicates that deleting th *.u2d file has no effect.
I am not using a network share.
Steven_L_Intel1
Can you attach a ZIP of the sources so that we can investigate? Might you have any circular module dependencies?
