29422 Discussions
Placement of SAVE statement within a module
Honari__Siavash
From a past forum discussion concerning the use of the SAVE statement, I know that adding a SAVE statement within the module is certainly the safest bet. However, I'm not sure where exactly to use the statement. For example, I don't know which of the following usages of SAVE statement are correct:
MODULE A
        IMPLICIT NONE
        SAVE
        INTEGER, PARAMETER:: B=0
END MODULE A
or
MODULE A
        IMPLICIT NONE
        SAVE
END MODULE A
Thanks for any info.
Steve_Lionel
You don't need to use SAVE in a module, but if you do, anywhere in the specification-part is fine. Note that as of F2008, the words about module data being defined as long as a USE was in scope has been removed - the reality is that module data is implicitly SAVE and the standard now reflects that.
jimdempseyatthecove
SAVE does not belong in modules. Module data is persistent and global to those that USE it.
Jim Dempsey
Steve_Lionel
Honari__Siavash
Thank you, Steve and Jim. I followed some of the old discussions suggesting that it is prudent to use the SAVE statement in the modules to ensure that all the variables are saved. Now if I understand correctly, it is not necessary but hopefully doesn't really hurt, right? Thanks
Steve_Lionel
It doesn’t hurt and is still allowed by the standard.
Honari__Siavash
Thanks alot
