Pointer Arithmetic
Nick3
I know how to do all this in C, but not in Fortran.
I realize this is a far-fetched solution that may or may not work, but here it goes.
I have this well defined:
REAL,POINTER :: HIJACKSTUFFREAL(:)
I also have:
TYPE(C_PTR) voidstar
INTEGER, POINTER :: IPTR(:)
For now, I managed to do this successfully:
voidstar = C_LOC(HIJACKSTUFFREAL)
What I need to do now is:
IPTR is a pointer of size (12345) at the address voidstar + z'1F48FCE0' - z'1F4D16E0'
How do I do that?
IanH
Why are you trying to do this?
(Check the variable names in your post.)
You can convert from the C address stored in a C_PTR object to an integer value of kind C_INTPTR_T using TRANSFER.  You can do arithmetic with integers.  You can convert back again using TRANSFER.  You can associate the object at the C address stored in a C_PTR object and a Fortran pointer using the C_F_POINTER procedure.
Be mindful whether your arithmetic/offsets/sizes are in bytes or size-of-the-scalar-object-being-pointed-at.
Knowing that the storage size of default real and integer are the same, and knowing the storage size of a default real can be queried by the STORAGE_SIZE intrinsic, you can probably skip all the C pointer conversion and just apply TRANSFER to the relevant array element.
But... why?
IanH
But... why?
Nick3
Excellent, I had to make  C_INTPTR_T a POINTER, but it's working great!
Well, we have to access a non-exported COMMON block in a DLL; we can look at this DLL, but can't really touch it.
Are you saying, something like this?
CALL C_F_POINTER(HIJACKSTUFFREAL+ offset in REALs rather than offset in bytes, IPTR, [ISIZE])
IanH
The INTEGER(C_INTPTR_T) would not have to be a POINTER.  If you think it does, show your code.
I thought your real array would cover the entire common block.  I see now that your offset would be a negative index beyond the start of that array.  Never mind.
Nick3
It crashed yesterday when I tried just INTEGER(C_INTPTR_T).  It doesn't crash today.
