Pointer release problem
Li_Dong
Dear all,
Here is a simplified case:
[fortran]program main
    type A
    end type A
    type, extends(A) :: B
        integer :: i = 0
    end type B
    type(B), pointer :: p1
    class(A), pointer :: p2
    allocate(p1)
    p2 => p1
    deallocate(p2)
end program main[/fortran]
I would like to release the memory allocated by "p1" through the handle "p2", but this case doesn't work.
How to accomplish it? Thanks!
dongli
mecej4
This is a dangerous way of handling pointers: allocating through p1, associating p2 with p1 and then deallocating through p2 leaves p1 associated but dangling, i.e., pointing to freed memory and, therefore, unusable.
Try adding
if(associated(p1))write(*,*) ' p1 is still associated'
after line 15 and see what is printed.
Li_Dong
Dear mecej4,
Actually, line 15 is not executed successfully at run time.
The error message is:
forrtl: severe (173): A pointer passed to DEALLOCATE points to an array that cannot be deallocated
dongli
mecej4
The action taken (if any) seems to depend on the compiler used. With this modification of your code:
type A
end type A
integer :: i = 0
end type B
integer :: istat
allocate(p1,stat=istat)
if(istat.ne.0)write(*,*)' Istat 1 : ',istat
p2 => p1
deallocate(p2,stat=istat)
if(istat.ne.0)write(*,*)' Istat 2 : ',istat
end program main
[/fortran]
Intel Fortran 12.0 says
[bash]  Istat 2 :          173
p1 is still allocated
[/bash]
whereas Gfortran 4.5 prints only the second line. NAG Fortran 5.2 says:
[bash]Runtime Error: ptr.f90, line 19: Dangling pointer P1 used as argument to intrinsic function ASSOCIATED
Target was DEALLOCATEd at line 17 of ptr.f90
Program terminated by fatal error
ptr.f90, line 19: Error occurred in MAIN[/bash]
Li_Dong
From your results, it seems that only NAG Fortran 5.2 gives the expected result!
All of the compilers give the result expected by the standard, though I like NAG's the best. If you deallocate all or part of storage pointed to by a pointer, that pointer's association status becomes undefined and calling ASSOCIATED on it or using the pointer is not allowed by the standard - results are unpredictable.
Li_Dong
I think the "associated" intrinsic function should provide more information, such as the content of pointer p1 has been released by another pointer p2, then associated(p1) should tell me ".false.".
jimdempseyatthecove
Associated cannot tell you that. It is your responsibility to dissassociate all pointers to object being deleted. Should that memory get re-allocated for something else, or a different object of the same type then a "pointing to allocated memory" indicator will produce a false positive (.false. for pointing to what you think it was).
Jim Dempsey
