Pointers and compiler error
gertdeboom
I'm experimenting a little with some form of cross-development between Compaq Visual Fortran 5.0D (used in a Windows 2000 environment) and Compaq Fortran V7.4A-1588-46B4K (used in OpenVMS 7.3 on Alpha).
The following code is running in both environments:
MODULE MOD_FORM
INCLUDE 'COMPABILITY.INC'
TYPE, PUBLIC:: FORM
CHARACTER*12 NAME
!DEC$ IF DEFINED (WINDOWS)
INTEGER*4 ONINPUT_PTR
!DEC$ ELSE
INTEGER*8 ONINPUT_PTR
!DEC$ ENDIF
END TYPE
PUBLIC:: FRM_SET_ONINPUT,FRM_INIT,FRM_EDIT
CONTAINS
!** FRM_SET_ONINPUT
SUBROUTINE FRM_SET_ONINPUT(OBJECT, FUNC)
TYPE(FORM) OBJECT
IF (.FALSE.) CALL FUNC('')
OBJECT%ONINPUT_PTR = %LOC(FUNC)
END SUBROUTINE
!** FRM_INIT
SUBROUTINE FRM_INIT(OBJECT)
TYPE(FORM) OBJECT
OBJECT%NAME = 'FIELDNAME'
END SUBROUTINE
!** FRM_EDIT
SUBROUTINE FRM_EDIT(OBJECT)
TYPE(FORM) OBJECT
EXTERNAL DUMMY
INTEGER*4 EVALUATION
!DEC$ ELSE
INTEGER*8 EVALUATION
!DEC$ ENDIF
POINTER(EVALUATION, DUMMY)
EVALUATION = OBJECT%ONINPUT_PTR
CALL DUMMY(OBJECT)
END SUBROUTINE
!DEC$ UNDEFINE WINDOWS
!DEC$ ENDIF
END
!** DUMMY
SUBROUTINE DUMMY
END
!** PROGRAM TEST
PROGRAM TEST
USE MOD_FORM
EXTERNAL BEFOREINPUT
TYPE(FORM) TSTFRM
CALL FRM_SET_ONINPUT(TSTFRM, BEFOREINPUT)
CALL FRM_INIT(TSTFRM)
CALL FRM_EDIT(TSTFRM)
END
!** BEFOREINPUT
SUBROUTINE BEFOREINPUT(TSTFRM)
USE MOD_FORM
TYPE(FORM) TSTFRM
WRITE(6,*) TSTFRM%NAME
END
The file "COMPATABILITY.INC" is supposed to contain
the line:
!DEC$ DEFINE WINDOWS
in the windows version. That way I'm making sure I
have one code base.
It is compiling and working correctly.
Only one thing worries me (and I'm not able to explain;
but I'm someone who doesn't like to learn theory) and
that is this line:
It doesn't do anything (apart from faking the compiler
I suppose) but if I skip it from the code both
compilers give the following error:
"This actual argument must not be the name of a procedure."
Could someone reading this forum explain me what is
happening here ? And is it safe to use this construction
in an actual program ?
I already know about the limited range of compilers
supporting this kind of pointer usage, but porting is
not an issue here.
Thanks in advance,
Gert
Jugoslav_Dujic
Valued Contributor II
Implicit typing is your enemy here.
Without that line, compiler does not know what's the type of FUNC argument, so it concludes that it's implicitly a REAL. When it sees call to FRM_SET_ONINPUT where the actual argument is a procedure, it complains about the mismatch.
What you really want is
EXTERNAL Func
declaration in FRM_SET_ONINPUT.
Few more notes: you better use standard F90 kinds instead of INTEGER*x form. Further, symbol _WIN32 is always defined in DVF for 32-bit Windows. It's far better to use:
!==8<==File "compatibility.inc"===
!DEC$IF DEFINED(_WIN32)
INTEGER, PARAMETER:: PTR = 4
CHARACTER(1), PARAMETER:: PATH=""
!DEC$ELSE
INTEGER, PARAMETER:: PTR = 8
CHARACTER(1), PARAMETER:: PATH="/"
!DEC$ENDIF
!==8<==File "Mod_form.f90"===
INCLUDE "compatibility.inc"
INTEGER(PTR):: ONINPUT_PTR
If you're lucky, you'll use !DEC$ only on one place -- in compatibility.inc. Note that I included PATH parameter as well; maybe you'll need it, like:
OPEN(11,FILE="."//PATH//ADir//PATH//File.txt).
As I've stressed already, I recommend using IMPLICIT NONE throughout -- requires more discipline but protects you from making stupid errors.
Jugoslav
gertdeboom
> What you really want is EXTERNAL Func
Kind of stupid. I knew I was faking the compiler somehow. Should have thought about it.
Thanks for your (really fast) answer and also for the other tips,
Gert
