29632 Discussions
Portability Function SIGNAL: Declaration and usage
markus
Playing around with SIGNAL (defined in IFPORT.F90) I have found:
  1. Documentation says "The result is the previous value of proc associated with the specified signal". But neither Windows nor Linux versions seem to return a valid value. Calling SIGNAL for the second time I would expect it returns the address of the signal handler specified at the previous call. Windows returns 0, Linux some random number.
  2. SIGNAL's interface defines proc as EXTERNAL. Thus it cannot be called with a variable as proc argument. But this is needed if I want to restore a previous signal handler as its address is stored in a variable.
Has someone had success with this?
Markus
Usage:
result = SIGNAL (signum, proc, flag)
Interface:
FUNCTION SIGNAL(SIGNUM, PROC, FLAG)
use ifport_types
!DEC$ ATTRIBUTES DEFAULT :: SIGNAL
INTEGER(POINTER_LEN) :: SIGNAL
INTEGER(4) :: SIGNUM, FLAG
INTEGER(4), EXTERNAL :: PROC
END FUNCTION
