Possible Bug in Intel 15
Douglas_M_
I've been working on a project that is compiled under a few different compilers for regression testing, and when we got to intel 15 for some reason a few cases encountered a divide by zero error.  I think that I've tracked the problem to a loop, and been able to reproduce it.  It's not a huge deal, and I think can actually be fixed with just compiler flags, I just wanted to get some thoughts on it.  I have two files, because I think the compiler optimizes differently when it has the number on hand than when it gets it passed in from somewhere else.  I'm also not sure if this problem still exists, as we're running on an older (a few months) than current version of Intel 15.
module test_abs
contains
subroutine test(factor)
  implicit none
  integer :: n
  real :: temp
  real :: a,asqr
  real, dimension(2) :: answer
  real, intent(in) :: factor
continue
  do n = 1,2
    asqr = factor * .7143
    a = sqrt(asqr)
    temp = 1.5
    temp = broke_fun(temp,.15,1E-17)
    answer(n) = temp
!write(*,*) 'fix'
  end do
write(*,*) answer(1)
end subroutine test
pure elemental function broke_fun(original,del,elim)
  implicit none
  real, intent(in) :: original,del,elim
  real             :: broke_fun
continue
  broke_fun = del + max(original-del, &
                          min(0.0, &
                              0.5*(original*original-del*del)/(max(del,elim))))
end function broke_fun
end module test_abs
And then the second file which uses this subroutine:
program main
use test_abs
  call test(1.4000000)
end program
The issue is that if you run the program as is, the answer given will be .15 when I think it should be 1.5.  If you remove the '!' in the "write(*,*) 'fix'" line, the answer given is 1.5.  I believe this is something to do with how the loop is optimized.  Obviously I can't just throw a write fix into a loop in the actual code, and I've tried !DIR$ SIMD_OFF NOVECTOR, NOFUSION, INLINE, but I think the problem is with the compiler flags.  These flags were picked because regression testing tends to start failing (we don't have fuzzy testing) when optimizing.
I've compiled with ifort -O2 -fp-model strict -fno-inline -ftrapuv *.F90 and when I remove either the -fp-model strict or the -fno-inline the problem disappears.  If I remove the -ftrapuv, the .15 becomes more or less random.
Doug
Would you please show the output of "ifort -V"? I am having difficulty reproducing this.
[sblionel@f90srv34 U560186]$ ifort -V -O2 -fp-model strict -fno-inline -ftrapuv *.f90
Intel(R) Fortran Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 15.0.3.187 Build 20150407
Copyright (C) 1985-2015 Intel Corporation.  All rights reserved.
 Intel(R) Fortran 15.0-1812
GNU ld version 2.20.51.0.2-5.20.el6 20091009
[sblionel@f90srv34 U560186]$ ./a.out
   1.500000
Douglas_M_
My build is slightly older, so it may be something that has been fixed in your newer version
$ ifort -V
Intel(R) Fortran Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 15.0.1.133 Build 20141023
Copyright (C) 1985-2014 Intel Corporation.  All rights reserved.
Could be. I can reproduce it with 15.0.0 (I don't happen to have 15.0.1 on my Linux system.) Please try a newer compiler.
