29277 Discussions
Possible bug in ifort and ifx with interface shadowing variable
D_Dickinson
I recently encountered a failure in CI for a build using ifx which appears to be due to some conflicts between a module level variable with the same name as an interface declared in a different module. This seems to impact the most recent ifx (on compiler explorer) back to at least ifort 19. The same code compiles with gfortran, flang and nvfortran.
In psuedo code the problem looks a bit like
file: first.f90
module first
interface the_name
end module first
file: second.f90
module second
logical :: the_name = .true.
contains
subroutine action
if(the_name) call sub_action
call second_action(arg = the_name)
end subroutine action
subroutine action
use first, only: the_name
call the_name
end module second
I find that ifx complains about line 8 of second.f90:
error #8164: A generic interface name shall not be used as an actual argument.   [THE_NAME]
compilation aborted for /app/example.f90 (code 1)
Compiler returned: 1
I have constructed a minimal example on the compiler explorer (with a slightly different setup): https://godbolt.org/z/5cY88nvez
D_Dickinson
Is there anything else I can provide to help with diagnosing this?
I appreciate that this might seem like it arises from bad practice (using the same name for two distinct objects), but I'm not aware of anything that should prevent this being valid fortran (might be lack of knowledge of my part though!). I can confirm that renaming on use (use first, only: the_name_ => the_name)  avoids the issue.
