Possible bug in ifort version 14.0.1
Momchil_I_
I have encountered some strange behaviour in the ifort version 14.0.1 by deliberately forcing an overflow of a 32 bit integer on my computer. Here is how to reproduce it
% ifort -v
% cat main.f90
program main
  implicit none
  integer i
  i=2**31-10
  do while(.true.)
     i=i+1
     if (i.le.0) then
        exit
     end if
  end do
  print *,'i',i
end program main
% ifort -O0 -std03 -o main main.f90
% ./main
 i -2147483648
% ifort -O1 -std03 -o main main.f90
% ./main
 i -2147483647
% ifort -O2 -std03 -o main main.f90
% ./main
 i -2147483647
I would expect  "i -2147483648" which I obtain with -O0 to be the correct behaviour. Am I missing something here?
Momchil
Momchil_I_
The following code shows the same behaviour
program main
  implicit none
  integer i
  i=2147483647-10
  do while(i.gt.0)
     i=i+1
  end do
  print *,'i',i
end program main
mecej4
This question has been addressed before. See https://software.intel.com/en-us/forums/topic/270242 .
Momchil_I_
Thank you, I will take a look at the huge() function, since that is what I was trying to achieve.
