Possible compiler bug?
Jacob_Williams
New Contributor III
I'm seeing some weird behavior on certain Linux systems for code that works fine on Windows (and also on other Linux systems). The example code is attached (reproducer.f90).  It has a class that contains a function pointer that is being associated to a subroutine that is contained within another subroutine.  My understanding is that this is valid?
My system is: HP DL360 G6, Intel(R) Xeon(R) X5570, CentOS 6.  I'm using Intel 16.0.1 20151021.
Compile with: ifort -g -traceback reproducer.f90 -o reproducer
Running it crashes (Not sure why I'm not getting the line numbers. What do I have to do to get those?):
$ ./reproducer
forrtl: severe (174): SIGSEGV, segmentation fault occurred
Image              PC                Routine            Line        Source
reproducer         0000000000477705  Unknown               Unknown  Unknown
reproducer         00000000004754C7  Unknown               Unknown  Unknown
reproducer         0000000000444DB4  Unknown               Unknown  Unknown
reproducer         0000000000444BC6  Unknown               Unknown  Unknown
reproducer         0000000000425CC6  Unknown               Unknown  Unknown
reproducer         00000000004032B0  Unknown               Unknown  Unknown
libpthread.so.0    0000003A0460F790  Unknown               Unknown  Unknown
Unknown            00007FFE9F1AD658  Unknown               Unknown  Unknown
However, running it in a debugger, it works fine:
$ gdb-ia ./reproducer
(gdb) run
Starting program: reproducer
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib64/libthread_db.so.1".
   3.00000000000000
[Inferior 1 (process 14138) exited normally]
(gdb)
Also interesting is that if I use "set disable-randomization off" in the debugger, it crashes again:
(gdb) set disable-randomization off
(gdb) run
Catchpoint -2 (signal SIGSEGV), 0x00007fff187ab458 in ?? ()
(gdb) where
#0  0x00007fff187ab458 in ?? ()
#1  0x00000000004030d5 in my_module::my_test () at reproducer.f90:42
#2  0x0000000000403175 in test () at reproducer.f90:71
#3  0x0000000000402e1e in main ()
#4  0x0000003a03a1ed5d in __libc_start_main () from /lib64/libc.so.6
#5  0x0000000000402d29 in _start ()
(gdb)
Any ideas? I think the code is valid, so maybe it's a compiler bug? However, since it does work on another similar Linux systems, I'm wondering if it could be some system-specific setting, but I don't know what would cause such behavior. (I normally work with the Windows compiler, so maybe more Linux-savvy folks can point me in the right direction).
jimdempseyatthecove
I think the issue is that a contained procedure must not be called from outside the procedure in which it is contained. This would be a requirement for the contained procedure to access variables in the procedure which contains it (proper stack framing).
I notice that your subroutine f does not reference variables within the containing procedure. Steve will be able to comment on this further, but you might be able to get by with it by making f PURE, though this may not work due to the contained pure subroutine potentially accessing the variables in the containing scope (not present when called via the pointer). I think it be best to extract the my_test contained subroutine f and place it in the outer scope contains section of the module, making it private (and potentially renaming it to my_test_f).
There was a different thread on one of the forums indicating that you cannot pass the address (pointer) of a private variable/procedure out of the module. In this case (after relocating f) you are not technically passing f out (excepting that the pointer f in instance of my_type is accessible).
Therefor the subroutine will have to be public (I assume).
This oop stuff is well beyond my expertise. I think I am more of an oops programmer.
Jim Dempsey
I don't see a problem with the source code. As long as you haven't left the instance of the containing procedure, it's ok to store and use a pointer to the contained procedure.
I am at home right now and tried this on Windows - it ran fine. I will try on Linux tomorrow as I think there the method of calling contained procedures is different.
I can't reproduce it on my Linux either, but as you note it works on some Linux systems and not others. Interesting point about ASLR, though that's supposed to change things run-to-run only.
It would be interesting to see a gdb instruction trace (with ASLR enabled) of the call.
break 42
run
display/i
stepi
and then repeat the stepi until you get to:
  callq  *%rax
print/x $rax
and then do more stepi until it fails. Paste the output here.
Jacob_Williams
New Contributor III
The display/i produces the message "Argument required (expression to compute)", and I never see the "callq ...".  But this is what I get:
No symbol table is loaded.  Use the "file" command.
GNU gdb (GDB) 7.8-16.0.558
Copyright (C) 2014 Free Software Foundation, Inc; (C) 2013-2015 Intel Corp.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
and "show warranty" for details.
This GDB was configured as "x86_64-unknown-linux-gnu".
Type "show configuration" for configuration details.
For information about how to find Technical Support, Product Updates,
User Forums, FAQs, tips and tricks, and other support information, please visit:
<http://www.intel.com/software/products/support/>.For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from ./reproducer...done.
(gdb) break 42
Breakpoint 1 at 0x402fb4: file reproducer.f90, line 42.
(gdb) run
Breakpoint 1, my_module::my_test () at reproducer.f90:42
42                      call blah%f(1.0_wp, 2.0_wp, xp)
(gdb) display/i
Argument required (expression to compute).
(gdb) stepi
0x0000000000402fbf      42                      call blah%f(1.0_wp, 2.0_wp, xp)
(gdb) stepi
0x0000000000402fca      42                      call blah%f(1.0_wp, 2.0_wp, xp)
(gdb) stepi
0x0000000000402fd5      42                      call blah%f(1.0_wp, 2.0_wp, xp)
(gdb) stepi
0x0000000000402fe0      42                      call blah%f(1.0_wp, 2.0_wp, xp)
(gdb) stepi
0x0000000000402fe7      42                      call blah%f(1.0_wp, 2.0_wp, xp)
(gdb) stepi
0x0000000000402fee      42                      call blah%f(1.0_wp, 2.0_wp, xp)
(gdb) stepi
0x0000000000402ff5      42                      call blah%f(1.0_wp, 2.0_wp, xp)
(gdb) stepi
0x0000000000402ff9      42                      call blah%f(1.0_wp, 2.0_wp, xp)
(gdb) stepi
0x0000000000403000      42                      call blah%f(1.0_wp, 2.0_wp, xp)
(gdb) stepi
0x000000000040300b      42                      call blah%f(1.0_wp, 2.0_wp, xp)
(gdb) stepi
0x0000000000403010      42                      call blah%f(1.0_wp, 2.0_wp, xp)
(gdb) stepi
0x0000000000403017      42                      call blah%f(1.0_wp, 2.0_wp, xp)
(gdb) stepi
0x000000000040301c      42                      call blah%f(1.0_wp, 2.0_wp, xp)
(gdb) stepi
0x0000000000403023      42                      call blah%f(1.0_wp, 2.0_wp, xp)
(gdb) stepi
0x000000000040302e      42                      call blah%f(1.0_wp, 2.0_wp, xp)
(gdb) stepi
0x0000000000403035      42                      call blah%f(1.0_wp, 2.0_wp, xp)
(gdb) stepi
0x0000000000403039      42                      call blah%f(1.0_wp, 2.0_wp, xp)
(gdb) stepi
0x0000000000403040      42                      call blah%f(1.0_wp, 2.0_wp, xp)
(gdb) stepi
0x000000000040304b      42                      call blah%f(1.0_wp, 2.0_wp, xp)
(gdb) stepi
0x0000000000403056      42                      call blah%f(1.0_wp, 2.0_wp, xp)
(gdb) stepi
0x0000000000403061      42                      call blah%f(1.0_wp, 2.0_wp, xp)
(gdb) stepi
0x000000000040306c      42                      call blah%f(1.0_wp, 2.0_wp, xp)
(gdb) stepi
0x0000000000403071      42                      call blah%f(1.0_wp, 2.0_wp, xp)
(gdb) stepi
0x0000000000403078      42                      call blah%f(1.0_wp, 2.0_wp, xp)
(gdb) stepi
0x0000000000403080      42                      call blah%f(1.0_wp, 2.0_wp, xp)
(gdb) stepi
0x0000000000403087      42                      call blah%f(1.0_wp, 2.0_wp, xp)
(gdb) stepi
0x000000000040308d      42                      call blah%f(1.0_wp, 2.0_wp, xp)
(gdb) stepi
0x0000000000403094      42                      call blah%f(1.0_wp, 2.0_wp, xp)
(gdb) stepi
0x000000000040309b      42                      call blah%f(1.0_wp, 2.0_wp, xp)
(gdb) stepi
0x000000000040309f      42                      call blah%f(1.0_wp, 2.0_wp, xp)
(gdb) stepi
0x00000000004030a6      42                      call blah%f(1.0_wp, 2.0_wp, xp)
(gdb) stepi
0x00000000004030ad      42                      call blah%f(1.0_wp, 2.0_wp, xp)
(gdb) stepi
0x00000000004030b4      42                      call blah%f(1.0_wp, 2.0_wp, xp)
(gdb) stepi
0x00000000004030b9      42                      call blah%f(1.0_wp, 2.0_wp, xp)
(gdb) stepi
0x00000000004030be      42                      call blah%f(1.0_wp, 2.0_wp, xp)
(gdb) stepi
0x00000000004030c2      42                      call blah%f(1.0_wp, 2.0_wp, xp)
(gdb) stepi
0x00000000004030c5      42                      call blah%f(1.0_wp, 2.0_wp, xp)
(gdb) stepi
0x00000000004030c9      42                      call blah%f(1.0_wp, 2.0_wp, xp)
(gdb) stepi
0x00000000004030cc      42                      call blah%f(1.0_wp, 2.0_wp, xp)
(gdb) stepi
0x00000000004030cf      42                      call blah%f(1.0_wp, 2.0_wp, xp)
(gdb) stepi
0x00000000004030d3      42                      call blah%f(1.0_wp, 2.0_wp, xp)
(gdb) stepi
0x00007ffe066d9fd8 in ?? ()
(gdb) stepi
Catchpoint -2 (signal SIGSEGV), 0x00007ffe066d9fd8 in ?? ()
(gdb) print/x $rax
$1 = 0x7ffe066d9fd8
(gdb)
Sorry, I meant "display/i $pc". But you showed enough to be interesting. That 7ffe... location is stack. When I run this I get this:
=> 0x4030d3 <__my_module_MOD_my_test+637>:      callq  *%rax
(gdb) print/x $rax
$1 = 0x7fffffffd6d8
(gdb) stepi
0x00007fffffffd6d8 in ?? ()
1: x/i $pc
=> 0x7fffffffd6d8:      movabs $0x403129,%r11
(gdb)
0x00007fffffffd6e2 in ?? ()
1: x/i $pc
=> 0x7fffffffd6e2:      movabs $0x0,%r10
(gdb)
0x00007fffffffd6ec in ?? ()
1: x/i $pc
=> 0x7fffffffd6ec:      rex.WB jmpq *%r11
(gdb)
my_module::f (me=0x3e0e18ced8 <main_arena+88>,
    a=<error reading variable: Cannot access memory at address 0x2567260c00000000>,
    b=<error reading variable: Cannot access memory at address 0x0>,
    c=<error reading variable: Cannot access memory at address 0x2567260c64a422ac>) at reproducer.f90:48
48                  subroutine f(me,a,b,c)
1: x/i $pc
=> 0x403129 <__my_module_MOD_f>:        push   %rbp
So you see it calls first into a stack "thunk" and which sets up the context and jumps to the real function. (The "error reading variable" messages are spurious and can be ignored.)
The address printed seems reasonable - but why you get a segfault there, I don't know. It could be there's something setting the stack as nonexecutable - I know that can be an issue. But why some Linux systems work and others don't, I don't know. I need to find someone here who understands this better than I do (not hard).
Can you tell me the exact Linux you have installed? uname -a
Jacob_Williams
New Contributor III
$ uname -a
Linux ngc11 2.6.32-573.8.1.el6.x86_64 #1 SMP Tue Nov 10 18:01:38 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
Jacob_Williams
New Contributor III
For completness, here is what I get when the run with the right "display/i $pc" command:
(gdb) break 42
Breakpoint 1 at 0x402fb4: file ./reproducer.f90, line 42.
(gdb) run
Breakpoint 1, my_module::my_test () at ./reproducer.f90:42
(gdb) display/i $pc
1: x/i $pc
=> 0x402fb4 <__my_module_MOD_my_test+350>:      movq   $0x0,-0xd8(%rbp)
(gdb) stepi
1: x/i $pc
=> 0x402fbf <__my_module_MOD_my_test+361>:      movq   $0x8,-0xe8(%rbp)
(gdb) stepi
1: x/i $pc
=> 0x402fca <__my_module_MOD_my_test+372>:      movq   $0x0,-0xd0(%rbp)
(gdb) stepi
1: x/i $pc
=> 0x402fd5 <__my_module_MOD_my_test+383>:      movq   $0x0,-0xe0(%rbp)
(gdb) stepi
1: x/i $pc
=> 0x402fe0 <__my_module_MOD_my_test+394>:      lea    -0x190(%rbp),%rax
(gdb) stepi
1: x/i $pc
=> 0x402fe7 <__my_module_MOD_my_test+401>:      mov    %rax,-0xf0(%rbp)
(gdb) stepi
1: x/i $pc
=> 0x402fee <__my_module_MOD_my_test+408>:      mov    -0xd8(%rbp),%rax
(gdb) stepi
1: x/i $pc
=> 0x402ff5 <__my_module_MOD_my_test+415>:      or     $0x1,%rax
(gdb) stepi
1: x/i $pc
=> 0x402ff9 <__my_module_MOD_my_test+419>:      mov    %rax,-0xd8(%rbp)
(gdb) stepi
1: x/i $pc
=> 0x403000 <__my_module_MOD_my_test+426>:      movq   $0x0,-0xe0(%rbp)
(gdb) stepi
1: x/i $pc
=> 0x40300b <__my_module_MOD_my_test+437>:      mov    $0x4921d0,%eax
(gdb) stepi
1: x/i $pc
=> 0x403010 <__my_module_MOD_my_test+442>:      mov    %rax,-0xc0(%rbp)
(gdb) stepi
1: x/i $pc
=> 0x403017 <__my_module_MOD_my_test+449>:      mov    $0x492218,%eax
(gdb) stepi
1: x/i $pc
=> 0x40301c <__my_module_MOD_my_test+454>:      mov    %rax,-0xb8(%rbp)
(gdb) stepi
1: x/i $pc
=> 0x403023 <__my_module_MOD_my_test+461>:      movq   $0x0,-0xb0(%rbp)
(gdb) stepi
1: x/i $pc
=> 0x40302e <__my_module_MOD_my_test+472>:      mov    -0xd8(%rbp),%rax
(gdb) stepi
1: x/i $pc
=> 0x403035 <__my_module_MOD_my_test+479>:      or     $0x2,%rax
(gdb) stepi
1: x/i $pc
=> 0x403039 <__my_module_MOD_my_test+483>:      mov    %rax,-0xd8(%rbp)
(gdb) stepi
1: x/i $pc
=> 0x403040 <__my_module_MOD_my_test+490>:      movq   $0x0,-0xa0(%rbp)
(gdb) stepi
1: x/i $pc
=> 0x40304b <__my_module_MOD_my_test+501>:      movq   $0x0,-0x90(%rbp)
(gdb) stepi
1: x/i $pc
=> 0x403056 <__my_module_MOD_my_test+512>:      movq   $0x0,-0x98(%rbp)
(gdb) stepi
1: x/i $pc
=> 0x403061 <__my_module_MOD_my_test+523>:      movq   $0x0,-0xa8(%rbp)
(gdb) stepi
1: x/i $pc
=> 0x40306c <__my_module_MOD_my_test+534>:      mov    $0x4921e0,%eax
(gdb) stepi
1: x/i $pc
=> 0x403071 <__my_module_MOD_my_test+539>:      mov    %rax,-0x88(%rbp)
(gdb) stepi
1: x/i $pc
=> 0x403078 <__my_module_MOD_my_test+546>:      movq   $0x0,-0x80(%rbp)
(gdb) stepi
1: x/i $pc
=> 0x403080 <__my_module_MOD_my_test+554>:      mov    -0xd8(%rbp),%rax
(gdb) stepi
1: x/i $pc
=> 0x403087 <__my_module_MOD_my_test+561>:      and    $0xffffffffffffff7f,%rax
(gdb) stepi
1: x/i $pc
=> 0x40308d <__my_module_MOD_my_test+567>:      mov    %rax,-0xd8(%rbp)
(gdb) stepi
1: x/i $pc
=> 0x403094 <__my_module_MOD_my_test+574>:      mov    -0xd8(%rbp),%rax
(gdb) stepi
1: x/i $pc
=> 0x40309b <__my_module_MOD_my_test+581>:      or     $0x2,%rax
(gdb) stepi
1: x/i $pc
=> 0x40309f <__my_module_MOD_my_test+585>:      mov    %rax,-0xd8(%rbp)
(gdb) stepi
1: x/i $pc
=> 0x4030a6 <__my_module_MOD_my_test+592>:      mov    -0x190(%rbp),%rax
(gdb) stepi
1: x/i $pc
=> 0x4030ad <__my_module_MOD_my_test+599>:      lea    -0xf0(%rbp),%rdx
(gdb) stepi
1: x/i $pc
=> 0x4030b4 <__my_module_MOD_my_test+606>:      mov    $0x492220,%ecx
(gdb) stepi
1: x/i $pc
=> 0x4030b9 <__my_module_MOD_my_test+611>:      mov    $0x492228,%ebx
(gdb) stepi
1: x/i $pc
=> 0x4030be <__my_module_MOD_my_test+616>:      lea    -0x70(%rbp),%rsi
(gdb) stepi
1: x/i $pc
=> 0x4030c2 <__my_module_MOD_my_test+620>:      mov    %rdx,%rdi
(gdb) stepi
1: x/i $pc
=> 0x4030c5 <__my_module_MOD_my_test+623>:      mov    %rsi,-0x20(%rbp)
(gdb) stepi
1: x/i $pc
=> 0x4030c9 <__my_module_MOD_my_test+627>:      mov    %rcx,%rsi
(gdb) stepi
1: x/i $pc
=> 0x4030cc <__my_module_MOD_my_test+630>:      mov    %rbx,%rdx
(gdb) stepi
1: x/i $pc
=> 0x4030cf <__my_module_MOD_my_test+633>:      mov    -0x20(%rbp),%rcx
(gdb) stepi
1: x/i $pc
(gdb) print/x $rax
$1 = 0x7fff5bd576d8
(gdb) stepi
0x00007fff5bd576d8 in ?? ()
1: x/i $pc
=> 0x7fff5bd576d8:      movabs $0x403129,%r11
(gdb) stepi
Catchpoint -2 (signal SIGSEGV), 0x00007fff5bd576d8 in ?? ()
1: x/i $pc
(gdb)
Thanks - that tells me at least that the "thunk" is at least being branched to. My guess is that it's some sort of execution protection. Let me see what I can find out. Are the other Linux systems also EL6? (Mine is also EL6, but a slightly older kernel.)
Oh, here's another question. If you change "initialize" to call the passed f there, rather then setting the pointer, does it work?
Oh, and on the original program, what happens if you do:
execstack -s ./reproducer
and then run the program (not in gdb)?
Jacob_Williams
New Contributor III
It still crashes. Code attached.
$ gdb-ia ./reproducer2
(gdb) run
Starting program: reproducer2
Catchpoint -2 (signal SIGSEGV), 0x00007ffd924b71c8 in ?? ()
(gdb) where
#0  0x00007ffd924b71c8 in ?? ()
#1  0x0000000000402e76 in my_module::initialize (me=0x7ffd924b7140) at ./reproducer2.f90:34
#2  0x0000000000402fd9 in my_module::my_test () at ./reproducer2.f90:45
#3  0x0000000000403027 in test () at ./reproducer2.f90:76
#4  0x0000000000402e1e in main ()
#5  0x0000003a03a1ed5d in __libc_start_main () from /lib64/libc.so.6
#6  0x0000000000402d29 in _start ()
(gdb)
Ok.
Also I would like to see the results of:
execstack -q ./reproducer
on the system where it fails and on a system where it works.
Jacob_Williams
New Contributor III
System where it works:
$ execstack -s ./reproducer
$ ./reproducer
   3.00000000000000
System where it doesn't work:
$ ./reproducer
Unknown            00007FFF672C89D8  Unknown               Unknown  Unknown
Another test - if you copy the executable from the system where it works to the one where it doesn't, does it run ok?
Jacob_Williams
New Contributor III
It's a cluster environment, so my home directory is shared on all the systems. I compile on the system that works and then can just ssh to the other one and run it from there. Compiling on one system vs the other doesn't seem to make a difference either.
So the same executable that works on one system fails on the other? What does execstack -q ./reproducer say on the two systems? It sure looks as if the issue is with the failing system overriding the flag in the executable saying to allow stack code to execute.
Jacob_Williams
New Contributor III
Both of them say:
X ./reproducer
Ok. Then there's something on the failing system overriding this - it's not in the compiler or linker. I'm not sure where to go from here.
jimdempseyatthecove
I notice that the crash occurred relating to libpthread.so.0 In some of my earlier experiences with pthread much of the documentation that you find on line was written for 32-bit systems and freely substituted "unsigned" for arguments that required an analog for handle which on 64-bit platform is 64-bits (e.g. uintptr_t). Using "unsigned" will (generally does, but sometimes not) cause failing code on 64-bit platforms.
Check your pthread return values and arguments, assuming you directly call pthread support routines. If you are not directly calling pthread routines (letting compiler generated OpenMP callse) then you may have a compatibility issue with the installed pthread library and/or openmp library.
Jim Dempsey
This really has nothing to do with threading, On the failing system, the kernel is not honoring the "ExecuteStack" flag in the ELF executable. Given that, calling contained procedures by passing them or storing pointers will not work.
