29386 Discussions
Possible to list preprocessor symbols/macros defined by ifort?
Bob_A_1
I'm working with a mixed C/Fortran project which uses waf as its cross-platform build system. While trying to resolve issues with ifort on Windows, the waf developers asked if there was a way to get ifort to list the preprocessor symbols or macros it defines because they need that info to support compilation with ifort.
As an example, if one runs
    gfortran.exe -dM -E - < a.f90
where a.f90 is an empty file, gfortran helpfully dumps out a long list of #defines (see attached).
Is this a thing ifort can do? I've looked into
    ifort /E /fpp a.f90 /dryrun
but I don't think that's doing quite the same thing.
There's more info on this issue at https://github.com/waf-project/waf/issues/1672 which revolves around the inability to get version information, etc. from ifort.
Thanks much,
mecej4
Have you tried ifort /# a.f90?
You can also use /list when compiling a source and look at the .lst file.
Bob_A_1
@mecej4 - no; where is /# documented? I don't think I've seen that before
@Steve - thanks, I've passed that to the project maintainers; we'll see what they say
mecej4
Whether documented or not, -# and -### are used by many compilers to turn on verbose output. See, for example, https://docs.oracle.com/cd/E18659_01/html/821-1384/bjapr.html#bjaps .
JVanB
Valued Contributor II
The ifort executable is not encrypted and the command-line switches are all in the same place in the file. A little experimentation and...
Bob_A_1
I asked where the compiler options were documented so I'd know next time where to look for this information rather than making a forum post. The answer appears that /# is undocumented, for whatever reason (deprecated, under development, etc.)
I hope that expecting users to filter their compiler binary through `strings` to discover legal options is more sarcasm than serious. Having been fighting with msvc, ifort, lib, and link for the past 2 days, I can't honestly tell anymore.
/# is indeed not documented, but it is not deprecated. I'll ask if it should be documented. We (Intel) don't expect users to run the compiler through "strings" - we document hundreds of options. I also gave you a documented way of getting the predefined symbols.
Lorri_M_Intel
It is purposefully undocumented; it's intended to be an internal-only switch because its meaning could change at a whim.
The one that is documented is /watch
              --Lorri
