- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
I have two VMS running Visual Studio 2012 Ultimate but they both have different versions of the Fortran compiler installed:
VM #1: Intel(R) Visual Fortran Compiler XE 14.0.6.241 [IA-32]
VM #2: Intel(R) Visual Fortran Compiler 17.0.4.210 [IA-32]
I have a simple Fortran test project on both VMs and I am testing an issue with preprocessor include files that was brought up to me. On VM #1 when you have a syntax error in the included header file and you try to double-click on the error in the Visual Studio error list window it does not take you to the exact line where the error is. However on VM #2 if you double-click on the error it does take you to the included file and the exact line where the syntax error is.
In what compiler version was this issue fixed? The only way I am able to get around it is to remove the preprocessor "#" in the include, build the project, and then you are able to double-click on the error. I have attached a screenshot with what I mean.
If you need more clarification let me know. Thank you!
JP
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Intel releases complete new installs, not patches. There would have been one version or update with the fix, not something that is "applied" to older versions. My guess is that this sort of bug was fixed in a major new version, not one of the updates. Try version 16. Perhaps one of the Intel folk can query the internal bug report database to see if they can locate my escalation of this issue. I am pretty sure the fix was in the compiler, not in fpp.
コピーされたリンク
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Precompiled headers would be for c++. As it's possible to install either of your ifort versions with or without Microsoft (and possibly also Intel) c++, I don't see what answers you could expect.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Tim I apologize I meant preprocessor includes not pre-compiled. I edited the post
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
I recall that there was a bug related to how preprocessor include files were identified by line number in the compiled source. It was fixed, but I don't remember in which version.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Try adding -P after -fpp (as additional command line option).
This removes the preprocessor annotations for #line-number file-name.
In older versions of IVF I had a similar problem with the line numbers in the debugger not lining up. This corrected the problem for me. It is easy enough for you to try.
Jim Dempsey
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Sounds good. I will contact support and see if they can query the bug report database and tell me the version where it got fixed. Thanks again for your help!
JP
