29386 Discussions
Premature analysis of open statement
Neil_Carlson
Here's a silly little problem I don't believe I've reported before, but which probably ought to be fixed.  The 14.0.2 and earlier compilers all complain about the following code
[fortran]
program main
open(newunit=n,status='replace',file='foo')
end program
[/fortran]
reporting
intel-bug-20121024.f90(19): error #8414: If NEWUNIT appears in OPEN statement either FILE or STATUS (with value SCRATCH) specifiers must appear.   [STATUS]
Clearly the compiler is not completely parsing the OPEN statement before checking the constraints for NEWUNIT.  I see nothing in the standard that requires a particular order of the indentifiers.
Neil_Carlson
Never mind.  By happenstance Steve recently replied to a very old topic started by dogunter, which I just read.  It turns out I did report this bug to my institutional HPC support and that was the basis for the old topic.  The issue ID is DPD200238261.
