Preprocessing Partial Words
Larry_R_
I want to use to the fpp preprocessor to achieve the following, however fpp doesnt seem to support the preprocessing of partial words. Is there a work around?
#ifdef DOUBLE_PRE
#define pre_ D0
#else
#define pre_ E0
#endif
myrealvar = 10.0pre_
FortranFan
Larry R. wrote:
I want to use to the fpp preprocessor to achieve the following, ..
Larry,
Depending on what all needs you have for the preprecessor, you may wish to consider an alternative based on Intel Fortran compiler directive syntax which I find more flexible:
MODULE MyKinds
   USE, INTRINSIC :: ISO_FORTRAN_ENV, ONLY : I4 => INT32, SP => REAL32, DP => REAL64, QP => REAL128
   IMPLICIT NONE
   !DEC$ IF DEFINED (SINGLE)
   INTEGER(I4), PARAMETER :: WP = SP
   !DEC$ IF DEFINED (DOUBLE)
   INTEGER(I4), PARAMETER :: WP = DP
   !DEC$ IF DEFINED (QUAD)
   INTEGER(I4), PARAMETER :: WP = QP
   !DEC$ ELSE
   INTEGER(I4), PARAMETER :: WP = SP  !.. Default
   !DEC$ ENDIF
END MODULE MyKinds
PROGRAM p
   USE MyKinds, ONLY : WP
   REAL(WP) :: x
   x = 1E3_wp
   PRINT *, " x = ", x
   STOP
END PROGRAM p
Lorri_M_Intel
I created a small program from your example above, and it seemed to work;
[ ~/project]$ ifort -fpp foo.f90 -E
# 1 "foo.f90"
# 5
myrealvar = 10.0E0
end
What did you see?
         --Lorri
mecej4
larry R.: I don't understand what you mean by "partial words". Perhaps, in your real code, you have C-style preprocessor directives that do not start in column-1 of the source file. For example, the following will not work
#ifdef DOUBLE_PRE
 #define pre_ D0
#else
 #define pre_ E0
#endif
program test
real x
double precision dx
dx = 10.0pre_
x = 10.0pre_
write(*,*)x,dx
end program
Moving '#' to the first column in Lines 2 and 4 will take care of the problem.
FortranFan
#ifdef DOUBLE_PRE
 #define pre_ D0
#else
 #define pre_ E0
#endif
program test
real x
double precision dx
dx = 10.0pre_
x = 10.0pre_
write(*,*)x,dx
end program
mecej4,
Does this hold the risk of loss of precision and mixed-mode arithmetic since a given instance have a single definition of "pre_" and a user uses the E0 definition with a real kind higher than that supported by E notation (e.g., your double precision dx)?
FortranFan
Larry,
MODULE MyKinds
   IMPLICIT NONE
   !DEC$ ELSE
   !DEC$ ENDIF
END MODULE MyKinds
PROGRAM p
   REAL(WP) :: x
   x = 1E3_wp
   PRINT *, " x = ", x
   STOP
END PROGRAM p
Larry_R_
FortranFan wrote:
Quote:
Larry,
MODULE MyKinds
   IMPLICIT NONE
   !DEC$ ELSE
   !DEC$ ENDIF
END MODULE MyKinds
PROGRAM p
   REAL(WP) :: x
   x = 1E3_wp
   PRINT *, " x = ", x
   STOP
END PROGRAM p
Hi Fortran Fan,
I like this solution but is there an alternative way to declare the exponent value? My reason for wanting to use D0 is to stop fortran from rounding when initializing variables with smaller precision numbers. For example, in double precision mode, if I initialized var = 10.15, fortran says var = 10.1499996185303. I know I should simply initialize as var = 10.1500000000000, however I am working with alot of code and it would be quite tedious to go through and do that for all variables.
TimP
Since f90, specifying a data type takes the place of the D promotion to double precision.
I don't see any reason why fpp conditional compilation couldn't be used with the f2008 data type naming suggested by Fortran Fan.
Larry_R_
Tim, I am looking for a method to make a condition compilation for the exponent value of a variable to prevent fortran from rounding double precision numbers.
What I am seeing is that double precsion data type declaration takes the place of D promotion, but not D0, D1, D3 ect.
mecej4
The common way of handling precision (single or double for the whole program) is to define a kind integer, say, 'wp' for working precision, inside a module, call it 'myprec', as follows:
module myprec
integer, parameter :: wp = kind(1.0)
end module
Then, wherever you have a constant in an expression, initialization expression, etc., you simply say, e.g., 3.14159264_wp, and add "USE myprec" in that subprogram. If you want, subsequently, to change from single to double precision, you need only change 1.0 to 1.0d0 in the module, and recompile everything that uses the module.
You can also use the selected_real_kind intrinsic function for more elaborate specifications of the kind of real numbers you wish to use.
JVanB
Valued Contributor II
var = 10.1500000000000 will not work. The approach with var = 10.15_wp or var = 0.1015e2_wp will work.
FortranFan
Larry R. wrote:
Hi Fortran Fan,
Larry,
As you may be aware, generally recommended coding practices (and which my colleagues and I strive to follow closely) include: avoid "magic" numbers in code and therefore, use named constants only and for commonly used constants in STEM fields, one can base them on easily accessible, but highly reliable and traceable references such as US NIST (www.nist.gov) or CRC Handbook, etc.   Include all the significant digits that are reported (e.g., for pi), even if they are greater than your typical working precision (let the compiler round-down per its rules but at least the code execution will be consistent for a given compiler with some selected settings).
With that in mind, you can a "constants" module that utilizes the KINDS module in Quote #4 above and "collects" all the constants in one place; the other code can then reference this module:
MODULE MyConstants
   USE MyKinds, ONLY : WP, ...
   !.. Fundamental physicals constants from US NIST website:
   !   http://physics.nist.gov/cgi-bin/cuu/Value?c|search_for=universal_in!
   REAL(WP), PARAMETER :: c0 = 299792458.0_wp   !.. Speed of light in vacuum, m/s
   REAL(WP), PARAMETER :: G  = 6.67384E-11_wp   !.. Newtonian constant of gravitation, m3 kg-1 s-2
END MODULE MyConstants
And you can see in the above snippet a couple of options  (c0, G) on how to specify the numerical values.  Try the above out with a working precision of Fortran 2008 intrinsic (defined in ISO_FORTRAN_ENV) of REAL64 (i.e., KIND=8 in Intel Fortran or the old-fashioned DOUBLE PRECISION) and see what you get.
JVanB
While I am myself a big fan of the usage in Quote #5, did you know that there is a quirk of the standard in that regard?
module invisible
! Pretend this module definition is not in the same file.
   implicit none
   integer, parameter :: REAL64 = kind(1.0)
end module invisible
module M1
   use invisible
   implicit none
   interface sub
      module procedure S1
      module procedure S2
   end interface sub
   contains
      subroutine S1(x)
         use ISO_FORTRAN_ENV
         real(REAL32) x
         write(*,*) 'Single-precision version was called.'
      end subroutine S1
      subroutine S2(x)
         use ISO_FORTRAN_ENV
         real(REAL64) x
         write(*,*) 'Double-precision version was called.'
      end subroutine S2
end module M1
module M2
   use M1
   contains
      subroutine S3
         use ISO_FORTRAN_ENV, only: wp => REAL64
         use ISO_FORTRAN_ENV
         implicit none
         real(REAL64) x
         call sub(x)
      end subroutine S3
end module M2
program P
   use M2
   implicit none
   call S3
end program P
The program actually calls the single precision version of sub. The line that causes the problem is the USE with ONLY: clause. If that were commented out, the double precision version would have been called. Not as dangerous as the quirks of the CMPLX intrinsic perhaps, but still a foot stuck out to trip the unwary.
jimdempseyatthecove
You'd have a similar situation with using fpp and competing #define's...
however, fpp will/should complain about re-#define without #undef(ine)
Fortran, as in above example #12, will permit you to redefine variables local scope that are otherwise defined in a module.
#12 may be a good case argument to have an attribute to declare a variable/parameter as not being re-definable, or at least warn on redefinition.
Jim Dempsey
FortranFan
A good catch.  I wonder if it would make sense for the standard to require something along the lines of
   INTEGER, PARAMETER, NON_INTRINSIC :: REAL64 = ..
whenever coders give variables the same names as those in the intrinsic modules and if that help avoid the issue raised by RO e.g., if some such keyword is attributed, then the user defined thing gets used instead of the intrinsic (similar to the EXTERNAL attribute on procedures with the same names as intrinsic functions).  Steve may have some thoughts on introducing such a thing into a future Fortran standard, or may have other suggestions on the issue raised by RO.
P.S.> Note the keyword NON_INTRINSIC I refer to above is already part of the standard (starting with 2003, I believe) but as I understand it, it is currently relevant to USE statements for modules where a coder might have access to user modules with the same name as the intrinsic modules (5 of them now, if I'm not mistaken such as ISO_FORTRAN_ENV).  So my thoughts are reusing this keyword as a variable attribute, if that makes sense!
Regarding RO's example in post 12, the ONLY is not relevant. What is relevant is the rename of ISO_FORTRAN_ENV's REAL64 to "wp", which is then not used in subroutine S3. This means that the local name REAL64 is host inherited from module M1. While I agree that the rules for use and host association can sometimes trip you up (see the "Up Periscope" section of Doctor Fortran in "Too Much of a Good Thing?"), I don't consider this a "quirk".
FortranFan's suggestion of NON_INTRINSIC to apply to other declarations is sort of beside the point - there is nothing special about the use of an intrinsic module here. A local declaration of a symbol always overrides any host-associated symbol. (If the same symbol is use-associated, then that's an error because you're not allowed to reference a symbol whose name is given to two or more local identifiers.)
FortranFan
Steve Lionel (Intel) wrote:
.. there is nothing special about the use of an intrinsic module here. A local declaration of a symbol always overrides any host-associated symbol. (If the same symbol is use-associated, then that's an error because you're not allowed to reference a symbol whose name is given to two or more local identifiers.)
Steve,
Do you have an example of "If the same symbol is use-associated, then that's an error because you're not allowed to reference a symbol whose name is given to two or more local identifiers"?  I thought such stipulations in the standards precluded code as shown below, but it doesn't appear to be so, at least with Intel Fortran and gfortran:
MODULE M1
   IMPLICIT NONE
   INTEGER, PARAMETER :: REAL64 = KIND(1.0)
END MODULE M1
MODULE M2
   USE M1, ONLY : REAL64
   IMPLICIT NONE
CONTAINS
   SUBROUTINE S
      USE ISO_FORTRAN_ENV, ONLY : REAL64
      IMPLICIT NONE
      REAL(REAL64) x
      PRINT *, " KIND(x) = ", KIND(x)
   END SUBROUTINE S
END MODULE M2
program test
use, intrinsic :: iso_fortran_env
integer, parameter :: REAL64=13 ! Error
end
Your example has host association, with different rules, as Richard Maine explained in comp.lang.fortran.
And this may also help illustrate:
module moda
integer, parameter :: x = 3
end module moda
module modb
integer, parameter :: x = 4
end module modb
program test
use moda
use modb
print *, x ! Ok until this statement
end
JVanB
What pulls my chain here is not the way use association overrides host association (I just put that in there so that removing a name from the namespace wouldn't cause an error because there was a backup name available from the host scope) but the rules about renaming. At its core, consider what happens if you have a module M2 with only one symbol, X. It just seems counterintuitive to me that 'USE M2' and 'USE M2, X=>X' should be semantically distinct, but the renaming rules dictate that they are.
In this example, as it stands, it prints out the X from M1, but if you uncomment the 'USE M2, X=>X' line, it prints out the X from M2. The 'USE M2' line makes all entities from M2 available but a rename clause on a different line can make entities available only under a different name and that seems confusing to be because looking at 'USE M2' in isolation it seems that everything in M2 should be available under its original name, but it turns out that this is negotiable, so you have to examine all USE statements for M2 to be sure whether any entity can be accessed via its original name.
module M1
   implicit none
   character(*), parameter :: x = 'The X from module M1.'
end module M1
module M2
   implicit none
   character(*), parameter :: x = 'The X from module M2.'
end module M2
module M3
   use M1
   implicit none
   contains
      subroutine sub
!         use M2, x => x
         use M2
         use M2, y => x
         implicit none
         write(*,'(a)') x
      end subroutine sub
end module M3
program P
   use M3
   implicit none
   call sub
end program P
Ah, but you're really not accessing it by its original name. You're accessing by a local name that happens to be spelled the same as the original name. You're right that you have to look at all the USE lines to check for ONLY and renames to get the sense of what entities are accessible and what their local names are. What you're touching on is that USE essentially creates a bunch of aliases for module entities - usually with the same spelling as the original name, but not always. In fact, this distinction becomes more important when it comes to public/private accessibility in that all the new local names start out fresh with accessibility.
jimdempseyatthecove
Could a module USE a different module on a statement containing x => y and have y private?
Jim Dempsey
