Print Project Compiler Settings
JKrob1
Is there a quick way to print out all my project compiler settings (Fortran and/or C++)?
Thanks in advance,
Jeff
jimdempseyatthecove
With a little work on your part, you can build a batch file (or other language) to locate all the "BuildLog.htm" files in the project output folders of interest (blabla\x64\BuildLog.htm) and extract the file names and options therein.
Jim Dempsey
jimdempseyatthecove
If your output files are positioned below some specific folder:
CD \ThatFolderHere
dir BuildLog.htm /s/b>logFiles.htm
Then you have a file list
*** Note, prior to doing this, perform a Clean, then build the configuration of interest. Not doing so will result in having Debug builds, Release builds and all other builds BuildLog.htm files listed.
Jim Dempsey
