29277 Discussions
Problem accessing file from FORTRAN DLL Subroutine
avinash_roshan
Hello;
I have the following situation:
I have a main function written in FORTRAN and a FORTRAN DLL.
I have one material database file.
Two subroutines has been defined inside the DLL file. One initializes the database file and other access the values defind in it and returns those values.
Inside main the structure of the code is like this:
PARAMETER (matdata='C:Matdatabedatabasefile.db')
PARAMETER (Ndat=31)
PARAMETER (Kdat=24)
CALLdatainit
OPEN(Kdat,FILE=matdata,STATUS='OLD',ERR=500)
READ(Kdat,'(A)') datfil
CLOSE(Kdat)
OPEN(Ndat,FILE=datfil,ACCESS='DIRECT',FORM='UNFORMATTED',
. SHARE='DENYNONE',RECL=3024,ERR=500)
CALL subroutine1('param1',Ndat)
When I compile the main program, the *.exe generated from it is able to access the DLL file. But it throws the error defined inside theDLL "database file not found" athough database file is there which is defined by the keyword here "datfil"
Could you tell me why this is happening. Any sort of help in this regard is welcome
Thankx
Avinash
The main program needs to be linked against the DLL form of the run-time libraries (matching the setting for your DLL.)
