Problem converting from CVF to IVF
michael_green
Hi All,
I have converted from CVF 6.6c to IVF 8.0 and plan to update to higher IVF shortly. In the meantime, when I attempt to link anything,I can't get past:
fatal error LNK1104: cannot open file "DFWIN.LIB"
The file, dfwinb.lib, is present in ...DF98LIB. Any suggestions?
With many thanks in advance,
Mike
onkelhotte
New Contributor II
Hi Mike,
i dont have any experience converting CVF6.6 to IVF8.0. A colleague of mine tried it a few years ago and he was not really succesful.
I converted a few projects from CVF6.6 to IVF9.0 myself and it was very simple. Intel improved a lot in Version 9 to make that kind of conversion as easy as possible and they made a good job.
So it would be better to convert from CVF6.6 directly to IVF9/10 instead of CVF6.6 to IVF8 and then to IVF9/10.
OnkelHotte
TimP
Ifort doesn't link against the libraries in your old CVF installation. The normal route is to rebuild any libraries which depend on compiler-dependent libraries.
As Tim suggests, this error is caused by not recompiling all Fortran source with the Intel compiler. You still have one or more objects or libraries in your project that were compiled with CVF.
