29375 Discussions
Problem converting from VS2008 to VS2013
Malcolm_C_
I've just installed visual studio 2013 and upgraded my intel visual fortran installation to the most current (2015 update).  I let VS upgrade the solution and project files of a number of my fortran-C mixed language solutions, all of which are fortran mains calling C libs (using VC compiler).  All compilations finished without fatal errors and the executables all run.  My problem is that when trying to run in debug mode I get the following error for all compiled solutions:  Unable to start program <c:\directory\solution_name_lib.lib> ... where directory is the directory containing the final executable and the C lib of the solution.  I've tried messing with the target directory properties of both fortran and C projects but to no avail.  Anyone got a clue?
Hmm, this does sound familiar. Let me look for the earlier reports of this, especially the properties not being correctly migrated.
Would you please attach a zip of a sample project that has this problem? Do a Build > Clean first.
Do you have this problem with the sample solution I have attached here? If so, please attach the .vfproj file from this one after you have converted it.
Malcolm_C_
Steve
I downloaded Fortran_Calls_C.zip from your last mail...converted it to vs2013 and it ran in debug mode (called from the DEBUG tab of Devenv) without a problem.
So the problem must be with how I've setup the solution on my side. Still clueless however.
Thanks again for the quick response,
Malcolm
Please attach the .vfproj file from your Fortran project.
