I have a child text window in a Quickwin program. I'm trying to mimic a button using a text region say 1 row high by 10 columns wide, starting at row 5 column 11:
CALL SETTEXTWINDOW (5, 11, 5, 20)
Write a text label 9 characters long to this area:
CALL SETTEXTPOSITION (1, 1, T)
CALL OUTTEXT ('123456789')
That works OK, and the 10th column of the "button" is left blank. But if instead I try to usethe *entire* button (i.e. every column of the text window):
CALL OUTTEXT ('1234567890')
Nothing at all is printed, resulting in a blank button label. Apparently it is impossible to write a character string X characters long into a text region X characters wide?!
It also appears to be impossible to write a single character to the last position of a text region:
CALL SETTEXTPOSITION (1, 10, T)
CALL OUTTEXT ('X')
This also fails to print anything.
What gives?
Unfortunately movetext and puttext have been removed from the CRTL.
Consider using WriteConsoleOutput.
Note, the data bufffer is in elements of CHAR_INFO {char, attribute}.
You can roll your own replacement for puttext using WriteConsoleOutput.
Jim Dempsey
So, I'll just accept that the last column of my text windows will always be blank and unusable.
DISPLAYCURSOR ($GCURSOROFF)
Or SETTEXTCURSOR (Z'0101')
Jim Dempsey
