29348 Discussions
Problem in building HDF5-1.10.6 with mpiifort.
Mohammad_Umair
Recently I tried to build the hdf5 library using the following set of instructions:
export CC=mpiicc
export CCP="mpiicc -E"
export FC=mpiifort
export CFLAGS="-o3 -mcmodel=medium -xHost -ip"
export FCFLAGS="-o3 -mcmodel=medium -xHost -ip"
export LIBS="-lz"
export LDFLAGS="-L/home/umair/zlib/zlib-1.2.11/lib"
export CPPFLAGS="-I/home/umair/zlib/zlib-1.2.11/include/"
mkdir ~/hdf5/hdf5-1.10.6
sudo ./configure --enable-parallel --enable-fortran --with-zlib=/home/umair/zlib/zlib-1.2.11 --prefix=/home/umair/hdf5/hdf5-1.10.6
sudo make
sudo make check
sudo make install
I have to use sudo, without it can't proceed. I have no idea why!!
The installation runs fine but after it completes when I check the libhdf5.settings, it shows Fortran Compiler: /usr/bin/mpif90
I need to use mpiifort but I don't know how to tackle this issue.
Kindly help!
PS: I have attached the libhdf5.settings file.
