29657 Discussions
Problem in linking Visual Studio with OneAPI Fortran Compiler
Sul32
When I open visual studio, it shows the message saying visual studio is not able to load OneAPI correctly.
The exact Error message is
The 'OneApiPackage' package did not load correctly.
The problem may have been caused by a configuration change or by the installation of another extension. You can get more information by examining the file 'C:\Users\vrs639\AppData\Roaming\Microsoft\VisualStudio\17.0_204bf235\ActivityLog.xml'. Restarting Visual Studio could help resolve this issue.
The activitylog.xml file and the error message there is
SetSite failed for package [OneApiPackage]Source: 'OneAPI' Description: Could not load file or assembly 'Microsoft.VisualStudio.Threading, Version=17.8.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The system cannot find the file specified. System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.VisualStudio.Threading, Version=17.8.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The system cannot find the file specified. File name: 'Microsoft.VisualStudio.Threading, Version=17.8.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' at OneApi.OneApiPackage.InitializeAsync(CancellationToken cancellationToken, IProgress`1 progress) at Microsoft.VisualStudio.Shell.AsyncPackage.<>c__DisplayClass20_0.<<Microsoft-VisualStudio-Shell-Interop-IAsyncLoadablePackageInitialize-Initialize>b__1>d.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Microsoft.VisualStudio.Threading.JoinableTask.<JoinAsync>d__76.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at Microsoft.VisualStudio.Services.VsTask.RethrowException(AggregateException e) at Microsoft.VisualStudio.Services.VsTask.InternalGetResult(Boolean ignoreUIThreadCheck) WRN: Assembly binding logging is turned OFF. To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1. Note: There is some performance penalty associated with assembly bind failure logging. To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
I'm trying to link VS2022+OneAPI+ABAQUS2023. While trying to verify the User subroutine in ABAQUS, I'm getting error saying problem in compilation which I believe is because of the above issue.
