I recently bought the upgrade from cvf standard 6.6 to professional and I am installing it on top of a CVF 6.6C installation.
It will not accept my serial number.
I have had problems installing my 6.6 which is an upgrade from 6.0 which was an upgrade from 5.0. The only way I could install 6.6 standard was if I first installed 5.0, then the 6.0 upgrade and finally the 6.6 upgrade. It would not take any of the earlier serial numbers if I tried to install without installing the 5.0 first.
So, trying to install 6.6 professional over 6.6 standard, it will not accept my 6.6 serial number.
It seems to have to do with the fact that I missed the 6.5 upgrade and went directly from 6.0 to 6.6.
I did download the fix for this, UPG66FIX.EXE, from
Problems upgrading to CVF 6.6? See http://compaq.com/fortran/kb/q1039.html
and this does not accept my serial number for the upgrade either. I tried both with and without the dashes between the numbers for the 6.6 professional upgrade.
My serial numbers are as follows:
5.0: deleted
6.0: deleted
6.6: deleted (standard)
I am installed OK up to here, cannot install:
6.6: deleted (professional)
What can I do to get this thing to install? I need it for a project!
Thanks in advance,
Charles.
Charles Stoyer
Interpex Limited
P.O. Box 839
Golden, CO 80402
Message Edited by sblionel on 03-20-2005 08:00 PM
I suggest you contact CVF support at vf-support@compaq.com I am sure they can help you.
It is not necessary to install 5.0 in order to install the 6.0 upgrade - all you needed was the serial number.
