29412 Discussions
Problem installing evaluation copy of Intel Fortran Composer XE 2011 for Linux and Mac OS X onto MAC platform
Martin_Hall
Hi
I have downloaded and installed the package m_fcompxe_2011.1.122.mpkg on Mac OS X 10.6 as an evaluation. However, when I try to run ifort I get the error message:
ifort: error #10310: Failed to enable trusted storage check for licensing: WARNING: Enable Trusted Storage failed (flexnet error code 1). Trusted Storage based license could not be supported
I was supplied with a product license file via email, but the instructions merely say 'You may need to copy the file manually to your system'- but doesn't say where to ? I appreciate this is a similar error to others aleady reported, but they did not invlove the mac platform, so the resolutions are not applicable in this case.
Any help much appreciated!
Martin
Kevin_D_Intel
Try dropping your license file into here (as root):
/Users/Shared/Library/Application Support/Intel/Licenses
And set permissions to include group/other "read" (file mode bits of at least "644")
Martin_Hall
Hi Kevin - thanks for your response; I'll give that a go.
Cheers,
Martin
Martin_Hall
Thanks - that seemed to do the trick!
Cheers,
Martin
Kevin_D_Intel
Excellent! Hope your evaluation goes well.
