Pointer allocation question
Li_Dong
Dear all,
I would like to allocate a pointer in the following way:
[fortran]module Mod_Test
    implicit none
    type A
    end type A
    type, extends(A) :: B
        integer i
    end type B
contains
    subroutine AllocateMemory(ptr)
        class(A), intent(inout), pointer :: ptr
        allocate(ptr)
    end subroutine AllocateMemory
end module Mod_Test
program main
    use Mod_Test
    implicit none
    class(B), pointer :: ptr
    call AllocateMemory(ptr)
end program main[/fortran]
That is allocate the actual pointer in type B through a pointer in type A. The output of ifort is
Test1.F90(47): error #6633: The type of the actual argument differs from the type of the dummy argument. [PTR]
compilation aborted for Test1.F90 (code 1)
How could I realize such thought?
Thanks very much
dongli
Li_Dong
Can it be done via interoperation with C?
dongli
jimdempseyatthecove
Your sketch code is functionally incorrect
Type B extends type A and is a larger object. Your allocation, if it were to work, would have allocated the smaller (NULL object in this case) object A, and returned a pointer to it (cast as an object of type B). IOW the resultant pointer would point to an object that spilled past the allocated memory.
If you really want to do this (and shoot yourself in the foot)you could UNION the two pointer types (or write code to futz with the pointers).
Jim Dempsey
Li_Dong
Hi, Jim,
Thank you for your reply! I know it is wrong, but the idea is to isolate the memory allocation from outside. This comes out when I want to create a generic linked list like "list" in STL for C++.
I can also provide the size of type B, and let the subroutine to allocate memory with such size, but the crucial point is that Fortran doesn't support type conversion like C/C++! So the dummy argument in type A can't be pointer, which make it impossible to allocate memory inside the subroutine.
dongli
