29487 Discussions
Problem linking FORTRAN and C++ .LIB that calls a managed function
Murali1
I have a large FORTRAN program that calls C++ functions linked as a static library using Microsoft Visual Studio 9. I supply the .LIB created by the C++ project to the FORTRAN linker. Previously I only used unmanged code. Now I want to extend the C++ function to use managed code.
So I added a new C++ function that is called from one of the existing C++ functions that itself is called from FORTRAN. The new C++ function is compiled using the /CLR option on the C++ side. The reason I did this is to be able to use .NET on the C++ side. How do I link this new .LIB file using FORTRAN linker? Now I receive a bunch of unresolved symbol and token messages. Just to make things clear I have drawn a diagram. (I hope the diagramis more clear than my description :) )
Program A (FORTRAN) ---> calls ---->C++ function B---> which in turn calls C++ function C compiled using /CLR
The first of several messages I receive from the FORTRAN linker is the following:
CPP.lib(CTest.obj) : error LNK2028: unresolved token (0A000006) "extern "C" void __clrcall ___CxxCallUnwindDtor(void (__clrcall*)(void *),void *)" (?___CxxCallUnwindDtor@@$$J0YMXP6MXPAX@Z0@Z) referenced in function "public: virtual __thiscall std::logic_error::~logic_error(void)" (??1logic_error@std@@$$FUAE@XZ)
Thanks in advance.
Murali
jirina
I use lib and dll written in C++ in my Fortran program too. It is quite complicated (for historical reasons) and it goes like this:
1. I have a dll with one function
[cpp]__declspec(dllexport) void WriteLogEntryNET
(char* appName, char* logName, char* message, int typeID, int eventID, int catID )[/cpp]
The function is supposed to write into the event log. This project is compiled in Visual Studio 2008 using following options:
[cpp]/O2 /Ob1 /Oy /D "WIN32" /D "_WINDOWS" /D "NDEBUG" /D "_USRDLL" /D "_AFXDLL" /D "_VC80_UPGRADE=0x0700" /D "_WINDLL" /D "_MBCS" /GF /FD /EHa /MD /Gy /Yu"stdafx.h" /Fp"ReleaseCppEventLog.pch" /Fo"Release" /Fd"Releasevc90.pdb" /W3 /nologo /c /Zi /clr /TP /errorReport:prompt[/cpp]
2. In another C++ project, I am creating a lib to be used by my Fortran program. Functions which are supposed to be called from Fortran are declared like this:
[cpp]extern "C" {
__declspec(dllexport) void __stdcall WriteLogEntry
(char* appName, int appNameLen,
char* logName, int logNameLen,
char* message, int messageLen,
int typeID, int eventID, int catID );
__declspec(dllexport) void __stdcall WorkingDirectory
(char* workDir, int workDirLen);
__declspec(dllexport) int __stdcall InitSignalProcessing
(void);
__declspec(dllexport) BOOL __stdcall CtrlHandler
(DWORD fdwCtrlType);
}[/cpp]
I'm using dll from step 1. to call the function WriteLogEntryNET.
Compiler options are:
[cpp]/O2 /Ob1 /Oy /D "WIN32" /D "_WINDOWS" /D "NDEBUG" /D "_USRDLL" /D "_VC80_UPGRADE=0x0700" /D "_WINDLL" /D "_MBCS" /GF /FD /EHsc /MT /Gy /Yu"stdafx.h" /Fp"ReleaseEventLog.pch" /Fo"Release" /Fd"Releasevc90.pdb" /W3 /nologo /c /Zi /TP /errorReport:prompt[/cpp]
dll from Step 1. is listed in Linker -> Input -> Delay Loaded DLLs.
3. Finally, Fortran code for one of the functions from Step 2. reads:
[cpp]      interface
        subroutine WriteLogEntry( appName, appNamelen, logName, logNameLen, msg, msgLen, typeID, eventID, catID )
        !dec$ attributes stdcall, dllimport, decorate, alias: "WriteLogEntry" :: WriteLogEntry
        ! Event log entry parameters
        character*30 appName
        character*20 logName
        character*1024 msg
        integer*4 appNameLen, logNameLen, msgLen
        integer*4 typeID, eventID, catID
        !dec$ attributes reference :: appName, logName, msg
        end subroutine WriteLogEntry
      end interface[/cpp]
Calling this function works well.
I have EventLog.lib from Step 2. included in my project and important linker options (for my program) are:
[cpp]/DELAYLOAD:"EventLog.dll" (dll from Step 2.) /IMPLIB:"D:...myApp.lib" delayimp.lib libguide.lib[/cpp]
I am not sure if anything from above will help you, but you might find something useful.
Murali1
Thanks for the quick reply. I want to make sure I understand exactly what you are doing.
The WriteLogEntryNet is called from WriteLogEntry (which is a C function) which in turn is being called from FORTRAN. the C functions called from FORTRAN are supplied through the static library. The C Static Library in turn is using the DLL. Am I right?
And you appear to have created a DLL to isolate managed code since WriteLogEntryNet uses the /clr compiler option. The other thing I don't understand is this. In step 2 I assume WriteLogEntry which is part of a static library project calls WriteLogEntryNet. How is it declared in the second .LIB project?
How is the first DLL supplied to step 2?
Thanks again.
jirina
You are right that the DLL from Step 1. (CppEventLog.dll) was created to isolate the managed code.
You are also right that the C function WriteLogEntry from Step 2. calls WriteLogEntryNET from CppEventLog.dll. The C library created in Step 2. is static.
Fortran code --> WriteLogEntry (static C library) --> WriteLogEntry (CppEventLog.dll)
CppEventLog from Step 1. is supplied to Step 2. by adding CppEventLog.lib to the project files. I also added CppEventLog.dll to Linker - Input - Delay Loaded DLLs.
To be able to call WriteLogEntryNET, I have following in the source code from Step 2.:
[cpp]typedef void (CALLBACK* WRITELOGENTRYNET)(char*,char*,char*,int,int,int);[/cpp]
I hope I did not forget anything.
