I need to read data lines on which there are positive integer numbers between two forward slashes (two slashes on each line). They are separated by one dash or an unknown number of blank characters, e.g. / 1 30 45-47 105 /
The dash separator represents a series of continues integers including the numbers just before and after the dash, in the above example: 45, 46 and 47. So in the example all the data must be read are: 1 , 30, 45, 46, 47 and 105 (the number of the integers on each lineand their digits are unknown).
My solution is to read each line as a character variable, then to scan the line letter by letter using internal reads. So I can find the number of the integers first, allocate my arrays and restart scanning to record the numbers. For this purpose I need to record the begging and end columns of each integer to read with variable format expressions.
Id appreciate any comment.
Many thanks
Hamid
it was a FOR file soI quickly converted to f90 with SPAG.
Thisupload is mainly to assist you in the many issues related to parsing a character array for numbers (real or integer)
obviously there are tools/functions which can clean this up, but it's a start!
enjoy!
brian
[cpp] SUBROUTINE READ1(Value,Icode)
IMPLICIT NONE
INTEGER :: Icode
REAL , DIMENSION(12) :: Value
INTENT (OUT) Icode
! Local variables
INTEGER :: i , j , jcode , jst , nword
INTEGER , DIMENSION(12) :: iend , istart
CHARACTER(1) :: jblnk , jbs , jcomma , jqm
CHARACTER(1) , DIMENSION(80) :: line
!*** End of declarations rewritten by SPAG
!* SUBROUTINE READ1(VALUE,ICODE)
!* FUNCTION: READS A LINE OF CHARACTERS AND EXTRACTS UP TO 12
!* NUMBERS FROM THAT LINE.
!* USER IS EXPECTED TO SEPARATE NUMBERS BY BLANKS OR COMMAS.
!* ANY ERRORS DETECTED WILL ONLY CAUSE A RETURN CODE, NOT
!* THE RUN TERMINATION WITH REGULAR FORTRAN I/O PROCESSING.
!* THUS, THIS IS AN IDIOT-PROOF WAY TO ENTER NUMERIC DATA
!* VIA THE KEYBOARD.
!* PARAMETERS: VALUE(12)----- ARRAY CONTAINING THE ENTERED NUMBERS.
!* ICODE--------- RETURN CODE: 1-12 = # OF VALID ENTRIES
!* 0 = BLANK LINE ENTERED
!* -1 = QUESTION MARK FOUND
!* -2 = BACKSPACE FOUND
!* -999 = SYNTAX ERROR
!* PROCEDURE: VARIABLES ARE INITIALIZED.
!* A LINE OF CHARACTERS IS READ WITH 80A1 FORMAT.
!* THE ENTERED LINE IS SCANNED FOR ? OR $ COMMAND CODES.
!* A DECIMITER SCAN FINDS THE START AND END OF EACH FIELD.
!* A LITTLE LOOP CALLS READ2 TO INTERPRET EACH FIELD.
!* VALID DATA ITEMS ARE LOADED INTO ARRAY VALUE.
!* ANY ERRORS CAUSE AN IMMEDIATE RETURN WITH THE
!* APPROPRIATE RETURN CODE.
!* VARIABLES USED: VALUE(12)------ ARRAY OF ENTERED NUMBERS
!* ICODE---------- SUBROUTINE RETURN CODE
!* ISTART(12)----- ARRAY OF FIELD STARTING LOCATIONS
!* IEND(12)------- ARRAY OF FIELD ENDING LOCATIONS
!* LINE(80)------- ARRAY TO HOLD 80 CHARACTER LINE
!* JST------------ 0=LOOKING FOR START OF NUMBER
!* 1=LOOKING FOR END OF NUMBER
!* NWORD---------- # OF NUMBERS ENTERED
!* JQM------------ QUESTION MARK CHARACTER (A1)
!* JBS------------ BACKSPACE CHARACTER (A1)
!* JBLNK---------- BLANK SPACE CHARACTER (A1)
!* JCOMMA--------- COMMA CHARACTER (A1)
!* JCODE---------- SUBROUTINE READ2 RETURN CODE)
DATA jblnk/' '/ , jqm/'?'/ , jbs/'$'/ , jcomma/','/
! INITIALIZE ALL ARRAYS
DO j = 1 , 12
istart(j) = 0
iend(j) = 0
Value(j) = 0.0
ENDDO
DO j = 1 , 80
line(j) = jblnk
ENDDO
! READ A LINE OF CHARACTERS
READ (5,10010) (line(j),j=1,80)
10010 FORMAT (80A1)
! SCAN ENTIRE LINE FOR QUESTION MARK (?) OR BACKSPACE ($)
DO j = 1 , 80
IF ( line(j)==jqm ) THEN
Icode = -1
RETURN
ELSEIF ( line(j)==jbs ) THEN
Icode = -2
RETURN
ELSE
ENDIF
ENDDO
DO
! DELIMITER SCAN
jst = 0
nword = 0
DO j = 1 , 80
IF ( jst==1 ) THEN
IF ( line(j)/=jblnk ) THEN
IF ( line(j)/=jcomma ) THEN
IF ( j<72 ) THEN
CYCLE
ENDIF
ENDIF
ENDIF
iend(nword) = j - 1
jst = 0
ELSEIF ( line(j)/=jblnk ) THEN
nword = nword + 1
IF ( nword>12 ) GOTO 200
istart(nword) = j
jst = 1
IF ( j>=80 ) THEN
iend(nword) = j
jst = 0
GOTO 100
ENDIF
ENDIF
ELSE
ENDIF
ENDDO
IF ( nword/=0 ) THEN
! USING THE LOCATED FIELDS, CALL READ2 TO CONSTRUCT THE NUMBER
DO i = 1 , nword
CALL READ2(line,Value(i),istart(i),iend(i),jcode)
IF ( jcode==-999 ) GOTO 200
ENDDO
Icode = nword
RETURN
ELSE
Icode = 0
RETURN
ENDIF
100 ENDDO
! ERROR SECTION HERE
200 Icode = -999
END SUBROUTINE READ1
SUBROUTINE READ2(Line,Result,Jstart,Jend,Icode)
IMPLICIT NONE
! Dummy arguments
INTEGER :: Icode , Jend , Jstart
REAL :: Result
CHARACTER(1) , DIMENSION(80) :: Line
INTENT (IN) Jend , Jstart , Line
INTENT (OUT) Icode , Result
! Local variables
INTEGER :: ex , idigit , j , jdigit , jdone , jexp , jmine , jminf , jpl , jpluse , jplusf , &
& jpoint , nex , se , x
REAL , INTRINSIC :: FLOAT
CHARACTER(1) :: iblnk , idecpt , iexp , iexpd , iminus , iplus , jchar
CHARACTER(1) , DIMENSION(10) :: itable
INTEGER , DIMENSION(10) :: jtable
REAL :: sx
!* SUBROUTINE READ2(LINE,RESULT,JSTART,JEND,ICODE)
!* PURPOSE: PERMITS IDIOT-PROOF READING OF A FIELD OF NUMERIC DATA.
!* IF REGULAR FORTRAN NUMERIC I/O IS USED, THE USER MAY
!* INADVERTANTLY MAKE A SPELLING ERROR AND CAUSE THE FORTRAN
!* I/O PROCESSOR TO TERMINATE THE RUN WITH A DIAGNOSTIC.
!* TO CIRCUMVENT THIS, SUBROUTINE READ2 SCANS A FIELD OF
!* CHARACTERS AND CONSTRUCTS THE DESIRED NUMERIC ITEM.
!* IF AN ERROR IS MADE, A RETURN CODE IS SET.
!* PARAMETERS: LINE---------- 80 CHARACTER ARRAY OF A1 FORMAT LITERAL
!* DATA PREVIOUSLY READ IN.
!* RESULT-------- THE ANSWER IN FLOATING POINT.
!* JSTART-------- POSITION AT WHICH THE FIELD STARTS.
!* JEND---------- POSITION AT WHICH THE FIELD ENDS.
!* ICODE--------- RETURN CODE -999 = ERROR
!* 0 = FIELD IS EMPTY
!* 1 = VALID RESULT
!* CONVENTIONS: ANY VALID INTEGER OR FLOATING POINT NUMBER MAY BE
!* ENTERED IN THE FIELD.
!* EMBEDDED BLANKS,INCOMPLETE NUMBERS,AND ILLEGAL
!* CHARACTERS WILL CAUSE AN ERROR RETURN CODE.
!* EXAMPLES OF VALID NUMBERS: 1527 -1527.31 *
!* -1527.31E-3
!* -.312E5
!* SYMBOLS: SX-------- SIGN OF FRACTIONAL PART
!* SE-------- SIGN OF EXPONENTIAL PART
!* X--------- FINAL FRACTIONAL PART
!* EX-------- FINAL EXPONENTIAL PART
!* NEX------- # OF DECIMAL PLACES IN FRACTIONAL PART
!* JPLUSF---- + SIGN FLAG (FRACTIONAL) 0 = LEGAL
!* 1 = NOT ALLOWED
!* JMINF----- - SIGN FLAG (FRACTIONAL) 0 = LEGAL
!* 1 = NOT ALLOWED
!* JPLUSE---- + SIGN FLAG (EXPONENTIAL) 0 = LEGAL
!* 1 = NOT ALLOWED
!* JMINE----- - SIGN FLAG (EXPONENTIAL) 0 = LEGAL
!* 1 = NOT ALLOWED
!* JPOINT---- DECIMAL POINT FLAG 0 = NO POINT FOUND
!* 1 = DECIMAL POINT FOUND
!* JEXP------ EXPONENT FLAG 0 = NO EXPONENT
!* 1 = EXPONENT FOUND
!* JDIGIT---- DIGIT FLAG 0 = NO DIGITS FOUND
!* 1 = FRACTIONAL DIGITS FOUND
!* 2 = EXPONENTIAL DIGITS FOUND
!* JDONE----- FIELD COMPLETION FLAG 0 = FIELD NOT FINISHED
!* 1 = NUMBER DONE
!* ICODE----- SUBROUTINE RETURN CODE (SEE PARAMETER LIST)
!* JCHAR----- SCALAR VERSION OF CURRENT CHARACTER
!* LINE(80)-- 80A1 FIELD OF CHARACTERS
!* ITABLE(10,2)- LOOKUP TABLE CHARACTER-TO-NUMERALS
!* IDIGIT---- NUMERIC EQUIVALENT OF CHARACTER
!* J--------- FIELD POSITION COUNTER
!* IBLNK----- BLANK CHARACTER
!* IPLUS----- PLUS CHARACTER
!* IMINUS---- MINUS CHARACTER
!* IDECPT---- DECIMAL POINT CHARACTER
!* IEXP------ EXPONENT MARK 'E'
!* IEXPD----- EXPONENT MARK 'D'
!* RESULT---- FLOATING POINT RESULT
!* SPECIAL THANKS TO GENE BUTLER FOR ASSISTANCE ON THIS
!* SUBROUTINE.
DATA iblnk/' '/ , iplus/'+'/ , iminus/'-'/ , idecpt/'.'/ , iexp/'E'/ , iexpd/'D'/
DATA itable/'0' , '1' , '2' , '3' , '4' , '5' , '6' , '7' , '8' , '9'/
DATA jtable/0 , 1 , 2 , 3 , 4 , 5 , 6 , 7 , 8 , 9/
! INITIALIZE ALL DATA
Icode = 0
jplusf = 0
jpluse = 0
jminf = 0
jmine = 0
jpoint = 0
jexp = 0
jdigit = 0
jdone = 0
se = 1
nex = 0
x = 0
ex = 0
j = 1
sx = 1.0
Result = 0.0
! FETCH THE NEXT CHARACTER
100 jchar = Line(Jstart+j-1)
! IS THE CHARACTER A BLANK ?
! NOTE: BLANKS ARE IGNORED TILL THE NUMBER STARTS.
! AFTER THAT, THE APPEARANCE OF A BLANK WILL END THE FIELD.
IF ( jchar/=iblnk ) THEN
! IS THE CHARACTER A PLUS SIGN?
! NOTE: IF THE FIELD IS FINISHED, A PLUS SIGN WILL SET AN ERROR CODE.
! IF (JPLUSF,JMINF,JEXP = 0) THIS IS THE FRACTION SIGN
! IF (JPLUSE,JMINE = 0, JEXP = 1) THIS IS THE EXPONENT SIGN
! ANYTHING ELSE WILL CAUSE AN ERROR.
IF ( jchar==iplus ) THEN
IF ( jdone/=1 ) THEN
IF ( (jplusf==0) .AND. (jminf==0) .AND. (jexp==0) ) THEN
sx = 1.0
jplusf = 1
GOTO 200
ELSEIF ( (jpluse==0) .AND. (jmine==0) .AND. (jexp==1) ) THEN
se = 1
jpluse = 1
GOTO 200
ELSE
ENDIF
ENDIF
Icode = -999
RETURN
! IS THE CHARACTER A MINUS SIGN?
! NOTE: IF THE FIELD IS FINISHED, A MINUS SIGN WILL CAUSE AN ERROR.
! ANYTHING ELSE IS AN ERROR.
ELSEIF ( jchar==iminus ) THEN
sx = -1.0
jminf = 1
GOTO 200
se = -1
jmine = 1
GOTO 200
ELSE
ENDIF
ENDIF
Icode = -999
RETURN
! IS THE CHARACTER A DECIMAL POINT
! NOTE: IF FIELD IS FINISHED, A DECIMAL POINT WILL CAUSE AN ERROR.
! DECIMAL POINTS ARE ONLY ALLOWED IN THE FRACTIONAL PART.
ELSEIF ( jchar==idecpt ) THEN
IF ( (jpoint==0) .AND. (jexp==0) ) THEN
jpoint = 1
jplusf = 1
jminf = 1
GOTO 200
ENDIF
ENDIF
Icode = -999
RETURN
! IS THE CHARACTER AN 'E' OR A 'D'?
! NOTE: IF THE FIELD IS FINISHED, AN EXPONENT WILL CAUSE AN ERROR.
! ONLY ONE EXPONENT MARK IS ALLOWED.
ELSEIF ( (jchar/=iexp) .AND. (jchar/=iexpd) ) THEN
! IS THE CHARACTER A VALID NUMERAL?
! NOTE: IF THE FIELD IS FINISHED, A NUMERAL WILL CAUSE AN ERROR.
! USE THE LOOKUP-TABLE TO GET THE NUMERIC EQUIVALENT.
DO jpl = 1 , 10
IF ( jchar==itable(jpl) ) THEN
idigit = jtable(jpl)
IF ( jdone==1 ) THEN
EXIT
ENDIF
IF ( jexp==1 ) THEN
! IF WE'RE DOING THE EXPONENTIAL PART, GET THE RUNNING EXPONENT.
ex = ex*10 + idigit
jdigit = 2
jpluse = 1
jmine = 1
ELSE
! IF WE'RE DOING THE FRACTIONAL PART, GET THE RUNNING ANSWER.
x = x*10 + idigit
nex = nex + jpoint
jdigit = 1
jplusf = 1
jminf = 1
ENDIF
GOTO 200
ENDIF
ENDDO
Icode = -999
RETURN
ELSE
IF ( jexp==0 ) THEN
jexp = 1
jpoint = 1
jplusf = 1
jminf = 1
GOTO 200
ENDIF
ENDIF
Icode = -999
RETURN
ENDIF
ELSEIF ( (jplusf/=0) .OR. (jminf/=0) .OR. (jpluse/=0) .OR. (jmine/=0) .OR. (jpoint/=0) .OR. &
& (jexp/=0) .OR. (jdigit/=0) ) THEN
jdone = 1
ELSE
ENDIF
! SEE IF THE END-OF-THE-FIELD HAS BEEN REACHED?
200 IF ( (Jstart+j-1)/=Jend ) THEN
j = j + 1
GOTO 100
! END-OF-FIELD HAS BEEN REACHED.
! NOTE: CHECK IF ENTIRE FIELD WAS COMPLETELY BLANK.
! CHECK IF ANY DIGITS AT ALL WERE ENCOUNTERED
! CHECK IF THE EXPONENTIAL PART HAD ANY DIGITS.
ELSEIF ( (jplusf==0) .AND. (jminf==0) .AND. (jpluse==0) .AND. (jmine==0) .AND. (jpoint==0) &
& .AND. (jexp==0) .AND. (jdigit==0) ) THEN
! HANDLE BLANK FIELD HERE.
Icode = 0
RETURN
ELSEIF ( jdigit>=1 ) THEN
IF ( (jexp/=1) .OR. (jdigit==2) ) THEN
! WORK OUT NUMERICAL RESULT HERE
Result = sx*FLOAT(x)*10.0**(se*ex-nex)
Icode = 1
GOTO 99999
ENDIF
ELSE
ENDIF
Icode = -999
RETURN
99999 END SUBROUTINE READ2
[/cpp]
enjoy!
brian
Appreciated very much. It is fairly similar to the subroutine I am writing.
Hamid
Hamid
I havent looked through the whole code of bmhenry...
I think all you need is "index" and "adjustl". The following code is written in this quote, I havent tested it in IVF, but it should work with a few modifications...
myCode is your line " 1 45-47 350 "
[cpp]character*255 tempstring, tempstring2,tempstring3
integer(kind=4) arraysize, dummyInt1, dummyInt2, posDash, arrayCounter, i
integer(kind=4), allocatable:: intArray(:)
arraysize = 0
read(tempstring,'(a)') myCode
! removing first
tempstring = tempstring(index(tempstring,'')+1:)
tempstring = adjustl(tempstring)
read(tempstring2,'(a)') tempstring
! getting the arraysize
do while(tempstring(1) /= '')
! removing leading blanks
read(tempstring3,'(a)') tempstring(:index(tempstring,' '))
posDash = index(tempstring3,'-')
if(posDash == 0) then
arraysize = arraysize + 1
else
! reading start and endvalue (not sure if -1 is right...)
read(dummyInt1,'(i)') tempstring3(:posDash-1)
read(dummyInt2,'(i)') tempstring3(posDash:)
arraysize = arraysize + (dummyInt2-dummyInt1+1)
end if
! removing number(s)
tempstring = tempstring(:index(tempstring,' '))
! remove leading blanks
end do
! filling the array
if (arraySize > 0) then
allocate intArray(arraySize))
arrayCounter = 1
do while(tempstring2(1) /= '')
read(tempstring3,'(a)') tempstring2(:index(tempstring2,' '))
read(intArray(arrayCounter),'(i)') = tempstring2(:index(tempstring2,' '))
arrayCounter = arrayCounter + 1
else
do i = dummyInt1,dummyInt2
read(intArray(arrayCounter),'(i)') = i
end do
end if
tempstring2 = tempstring(:index(tempstring2,' '))
tempstring2 = adjustl(tempstring2)
end do
end if
[/cpp]
I didn't look closely but a couple of things caught my eye.
Minor points :
"" is "/" in the original
replace internal read for tempstring2 with
tempstring2 = tempstring.
(apart from being wrong way round) why not just
tempstring3 = adjustl(tempstring(:index(tempstring,' ')))
The internal reads need swapping round e.g. :
should be
read(tempstring3(:posdash-1), '(i)' ) dummyInt1 ! format could be (*)
read(tempstring3(posDash+1:), '(i)' ) dummyInt2 ! Need to bypass thedash "-"
Les
Minor points :
should be
Les
Many thanks. You are right. The code needs modification. Please see post 6.
Hamid
Thank you very much for your kind consideration. It is possible not to have a blank character between the last number and the second "/". Also there are some data after the second slash, so I modified your code, but got a strange problem in getting the array size.
character*255 tempstring, tempstring1, tempstring2,tempstring3
character*255 tempstring4
character*255 dummyInt20
& arrayCounter, i
arraysize = 0
OPEN(unit = 2, file = 'zread.dat')
READ (UNIT = 2, FMT = "(a)") tempstring
! removing first /
tempstring = tempstring(index(tempstring,'/')+1:)
! removing last /
tempstring = tempstring(:index(tempstring,'/')-1)
do while(tempstring .NE. ' ')
read(tempstring,'(a)') tempstring3(:index(tempstring,' '))
PRINT*, 'tempstring3',tempstring3,'posDash',posDash
if(posDash .EQ. 0) then
else
tempstring3 = adjustl(tempstring3)
read(tempstring3(:posDash-1),'(i)') dummyInt1
PRINT*, 'dummyInt1',dummyInt1
10 read(tempstring3(posDash+1:),'(a)') tempstring4
20 PRINT*, 'tempstring4',tempstring4
30 read(tempstring3(posDash+1:),'(i)') dummyInt2
40 PRINT*, 'dummyInt2',dummyInt2
end if
tempstring = tempstring(index(tempstring,' '):)
end do
PRINT*, 'arraysize',arraysize
END
In reading a data file like / 12 30-132 33 45 / 3, the code cannot read the number after the dash (132). Using similar format it can be read with a string character (tempstring4), but not with the integer variable (dummyInt2). The error I get is:
forrtl: severe (64): input conversion error, unit -5, file Internal Formatted Re
Does anyone know what's wrong?
Many thanks
Hamid
You can do it that way:
30 read(tempstring3(posDash+1:index(tempstring,' ')),'(i)') dummyInt2
Markus
Markus
Many thanks Markus. You are absolutely right!
Hamid
