29255 Diskussionen
I/O formatting - read data separated by blank or dash characters
h_amini
Einsteiger
2.179Aufrufe
I need to read data lines on which there are positive integer numbers between two forward slashes (two slashes on each line). They are separated by one dash or an unknown number of blank characters, e.g. / 1 30 45-47 105 /
The dash separator represents a series of continues integers including the numbers just before and after the dash, in the above example: 45, 46 and 47. So in the example all the data must be read are: 1 , 30, 45, 46, 47 and 105 (the number of the integers on each lineand their digits are unknown).
My solution is to read each line as a character variable, then to scan the line letter by letter using internal reads. So I can find the number of the integers first, allocate my arrays and restart scanning to record the numbers. For this purpose I need to record the begging and end columns of each integer to read with variable format expressions.
Id appreciate any comment.
Many thanks
Hamid
8 Antworten
bmchenry
Neuer Beitragender II
2.179Aufrufe
your question reminds me of some old code from mainframe/mini computer daze, and so i am uploading a read1/read2 routine which parses a character array for up to 12 numbers.
it was a FOR file soI quickly converted to f90 with SPAG.
Thisupload is mainly to assist you in the many issues related to parsing a character array for numbers (real or integer)
obviously there are tools/functions which can clean this up, but it's a start!
enjoy!
brian
[cpp]      SUBROUTINE READ1(Value,Icode)
      IMPLICIT NONE
      INTEGER :: Icode
      REAL , DIMENSION(12) :: Value
      INTENT (OUT) Icode
! Local variables
      INTEGER :: i , j , jcode , jst , nword
      INTEGER , DIMENSION(12) :: iend , istart
      CHARACTER(1) :: jblnk , jbs , jcomma , jqm
      CHARACTER(1) , DIMENSION(80) :: line
!*** End of declarations rewritten by SPAG
!*		          SUBROUTINE READ1(VALUE,ICODE)
!*            FUNCTION: READS A LINE OF CHARACTERS AND EXTRACTS UP TO 12
!*	                NUMBERS FROM THAT LINE.
!*	                USER IS EXPECTED TO SEPARATE NUMBERS BY BLANKS OR COMMAS.
!*	                ANY ERRORS DETECTED WILL ONLY CAUSE A RETURN CODE, NOT
!*	                THE RUN TERMINATION WITH REGULAR FORTRAN I/O PROCESSING.
!*	                THUS, THIS IS AN IDIOT-PROOF WAY TO ENTER NUMERIC DATA
!*	                VIA THE KEYBOARD.
!*            PARAMETERS: VALUE(12)----- ARRAY CONTAINING THE ENTERED NUMBERS.
!*		ICODE--------- RETURN CODE: 1-12 = # OF VALID ENTRIES
!*					                 0 = BLANK LINE ENTERED
!*					                -1 = QUESTION MARK FOUND
!*					                -2 = BACKSPACE FOUND
!*					              -999 = SYNTAX ERROR
!*            PROCEDURE:	VARIABLES ARE INITIALIZED.
!*		A           LINE OF CHARACTERS IS READ WITH 80A1 FORMAT.
!*		THE           ENTERED LINE IS SCANNED FOR ? OR $ COMMAND CODES.
!*		A           DECIMITER SCAN FINDS THE START AND END OF EACH FIELD.
!*		A           LITTLE LOOP CALLS READ2 TO INTERPRET EACH FIELD.
!*		VALID           DATA ITEMS ARE LOADED INTO ARRAY VALUE.
!*		ANY           ERRORS CAUSE AN IMMEDIATE RETURN WITH THE
!*		APPROPRIATE RETURN CODE.
!*            VARIABLES USED: VALUE(12)------ ARRAY OF ENTERED NUMBERS
!*		              ICODE---------- SUBROUTINE RETURN CODE
!*		              ISTART(12)----- ARRAY OF FIELD STARTING LOCATIONS
!*		              IEND(12)------- ARRAY OF FIELD ENDING LOCATIONS
!*		              LINE(80)------- ARRAY TO HOLD 80 CHARACTER LINE
!*		              JST------------ 0=LOOKING FOR START OF NUMBER
!*				              1=LOOKING FOR END OF NUMBER
!*		              NWORD---------- # OF NUMBERS ENTERED
!*		              JQM------------ QUESTION MARK CHARACTER (A1)
!*		              JBS------------ BACKSPACE CHARACTER (A1)
!*		              JBLNK---------- BLANK SPACE CHARACTER (A1)
!*		              JCOMMA--------- COMMA CHARACTER (A1)
!*		              JCODE---------- SUBROUTINE READ2 RETURN CODE)
      DATA jblnk/' '/ , jqm/'?'/ , jbs/'$'/ , jcomma/','/
!             INITIALIZE ALL ARRAYS
      DO j = 1 , 12
         istart(j) = 0
         iend(j) = 0
         Value(j) = 0.0
      ENDDO
      DO j = 1 , 80
         line(j) = jblnk
      ENDDO
!             READ A LINE OF CHARACTERS
      READ (5,10010) (line(j),j=1,80)
10010 FORMAT (80A1)
!             SCAN ENTIRE LINE FOR QUESTION MARK (?) OR BACKSPACE ($)
      DO j = 1 , 80
         IF ( line(j)==jqm ) THEN
            Icode = -1
            RETURN
         ELSEIF ( line(j)==jbs ) THEN
            Icode = -2
            RETURN
         ELSE
         ENDIF
      ENDDO
      DO
!             DELIMITER SCAN
         jst = 0
         nword = 0
         DO j = 1 , 80
            IF ( jst==1 ) THEN
               IF ( line(j)/=jblnk ) THEN
                  IF ( line(j)/=jcomma ) THEN
                     IF ( j<72 ) THEN
                        CYCLE
                     ENDIF
                  ENDIF
               ENDIF
               iend(nword) = j - 1
               jst = 0
            ELSEIF ( line(j)/=jblnk ) THEN
                  nword = nword + 1
                  IF ( nword>12 ) GOTO 200
                  istart(nword) = j
                  jst = 1
                  IF ( j>=80 ) THEN
                     iend(nword) = j
                     jst = 0
                     GOTO 100
                  ENDIF
               ENDIF
            ELSE
            ENDIF
         ENDDO
         IF ( nword/=0 ) THEN
!             USING THE LOCATED FIELDS, CALL READ2 TO CONSTRUCT THE NUMBER
            DO i = 1 , nword
               CALL READ2(line,Value(i),istart(i),iend(i),jcode)
               IF ( jcode==-999 ) GOTO 200
            ENDDO
            Icode = nword
            RETURN
         ELSE
            Icode = 0
            RETURN
         ENDIF
 100  ENDDO
!             ERROR SECTION HERE
 200  Icode = -999
      END SUBROUTINE READ1
      SUBROUTINE READ2(Line,Result,Jstart,Jend,Icode)
      IMPLICIT NONE
! Dummy arguments
      INTEGER :: Icode , Jend , Jstart
      REAL :: Result
      CHARACTER(1) , DIMENSION(80) :: Line
      INTENT (IN) Jend , Jstart , Line
      INTENT (OUT) Icode , Result
! Local variables
      INTEGER :: ex , idigit , j , jdigit , jdone , jexp , jmine , jminf , jpl , jpluse , jplusf ,  &
               & jpoint , nex , se , x
      REAL , INTRINSIC :: FLOAT
      CHARACTER(1) :: iblnk , idecpt , iexp , iexpd , iminus , iplus , jchar
      CHARACTER(1) , DIMENSION(10) :: itable
      INTEGER , DIMENSION(10) :: jtable
      REAL :: sx
!*	           SUBROUTINE  READ2(LINE,RESULT,JSTART,JEND,ICODE)
!*            PURPOSE: PERMITS IDIOT-PROOF READING OF A FIELD OF NUMERIC DATA.
!*	               IF REGULAR FORTRAN NUMERIC I/O IS USED, THE USER MAY
!*	               INADVERTANTLY MAKE A SPELLING ERROR AND CAUSE THE FORTRAN
!*	               I/O PROCESSOR TO TERMINATE THE RUN WITH A DIAGNOSTIC.
!*	               TO CIRCUMVENT THIS, SUBROUTINE READ2 SCANS A FIELD OF
!*	               CHARACTERS AND CONSTRUCTS THE DESIRED NUMERIC ITEM.
!*	               IF AN ERROR IS MADE, A RETURN CODE IS SET.
!*            PARAMETERS: LINE---------- 80 CHARACTER ARRAY OF A1 FORMAT LITERAL
!*			                 DATA PREVIOUSLY READ IN.
!*		RESULT-------- THE ANSWER IN FLOATING POINT.
!*		JSTART-------- POSITION AT WHICH THE FIELD STARTS.
!*		JEND---------- POSITION AT WHICH THE FIELD ENDS.
!*		ICODE--------- RETURN CODE  -999 = ERROR
!*					                 0 = FIELD IS EMPTY
!*					                 1 = VALID RESULT
!*            CONVENTIONS: ANY VALID INTEGER OR FLOATING POINT NUMBER MAY BE
!*		           ENTERED IN THE FIELD.
!*		           EMBEDDED BLANKS,INCOMPLETE NUMBERS,AND ILLEGAL
!*		           CHARACTERS WILL CAUSE AN ERROR RETURN CODE.
!*		           EXAMPLES OF VALID NUMBERS:  1527		       					              -1527.31		       *
!*					              -1527.31E-3
!*					              -.312E5
!*            SYMBOLS: SX-------- SIGN OF FRACTIONAL PART
!*	               SE-------- SIGN OF EXPONENTIAL PART
!*	               X--------- FINAL FRACTIONAL PART
!*	               EX-------- FINAL EXPONENTIAL PART
!*	               NEX------- # OF DECIMAL PLACES IN FRACTIONAL PART
!*	               JPLUSF---- + SIGN FLAG (FRACTIONAL)      0 = LEGAL
!*						                1 = NOT ALLOWED
!*	               JMINF----- - SIGN FLAG (FRACTIONAL)      0 = LEGAL
!*						                1 = NOT ALLOWED
!*	               JPLUSE---- + SIGN FLAG (EXPONENTIAL)     0 = LEGAL
!*						                1 = NOT ALLOWED
!*	               JMINE----- - SIGN FLAG (EXPONENTIAL)     0 = LEGAL
!*						                1 = NOT ALLOWED
!*	               JPOINT---- DECIMAL POINT FLAG  0 = NO POINT FOUND
!*					              1 = DECIMAL POINT FOUND
!*	               JEXP------ EXPONENT FLAG  0 = NO EXPONENT
!*				                 1 = EXPONENT FOUND
!*	               JDIGIT---- DIGIT FLAG  0 = NO DIGITS FOUND
!*				              1 = FRACTIONAL DIGITS FOUND
!*				              2 = EXPONENTIAL DIGITS FOUND
!*	               JDONE----- FIELD COMPLETION FLAG 0 = FIELD NOT FINISHED
!*					                1 = NUMBER DONE
!*	               ICODE----- SUBROUTINE RETURN CODE (SEE PARAMETER LIST)
!*	               JCHAR----- SCALAR VERSION OF CURRENT CHARACTER
!*	               LINE(80)-- 80A1 FIELD OF CHARACTERS
!*	               ITABLE(10,2)- LOOKUP TABLE  CHARACTER-TO-NUMERALS
!*	               IDIGIT---- NUMERIC EQUIVALENT OF CHARACTER
!*	               J--------- FIELD POSITION COUNTER
!*	               IBLNK----- BLANK CHARACTER
!*	               IPLUS----- PLUS CHARACTER
!*	               IMINUS---- MINUS CHARACTER
!*	               IDECPT---- DECIMAL POINT CHARACTER
!*	               IEXP------ EXPONENT MARK 'E'
!*	               IEXPD----- EXPONENT MARK 'D'
!*	               RESULT---- FLOATING POINT RESULT
!*              SPECIAL THANKS TO GENE BUTLER FOR ASSISTANCE ON THIS
!*              SUBROUTINE.
      DATA iblnk/' '/ , iplus/'+'/ , iminus/'-'/ , idecpt/'.'/ , iexp/'E'/ , iexpd/'D'/
      DATA itable/'0' , '1' , '2' , '3' , '4' , '5' , '6' , '7' , '8' , '9'/
      DATA jtable/0 , 1 , 2 , 3 , 4 , 5 , 6 , 7 , 8 , 9/
!             INITIALIZE ALL DATA
      Icode = 0
      jplusf = 0
      jpluse = 0
      jminf = 0
      jmine = 0
      jpoint = 0
      jexp = 0
      jdigit = 0
      jdone = 0
      se = 1
      nex = 0
      x = 0
      ex = 0
      j = 1
      sx = 1.0
      Result = 0.0
!             FETCH THE NEXT CHARACTER
 100  jchar = Line(Jstart+j-1)
!             IS THE CHARACTER A BLANK ?
!             NOTE: BLANKS ARE IGNORED TILL THE NUMBER STARTS.
!	AFTER             THAT, THE APPEARANCE OF A BLANK WILL END THE FIELD.
      IF ( jchar/=iblnk ) THEN
!             IS THE CHARACTER A PLUS SIGN?
!             NOTE: IF THE FIELD IS FINISHED, A PLUS SIGN WILL SET AN ERROR CODE.
!	IF              (JPLUSF,JMINF,JEXP = 0)    THIS IS THE FRACTION SIGN
!	IF             (JPLUSE,JMINE = 0, JEXP = 1)  THIS IS THE EXPONENT SIGN
!	ANYTHING             ELSE WILL CAUSE AN ERROR.
         IF ( jchar==iplus ) THEN
            IF ( jdone/=1 ) THEN
               IF ( (jplusf==0) .AND. (jminf==0) .AND. (jexp==0) ) THEN
                  sx = 1.0
                  jplusf = 1
                  GOTO 200
               ELSEIF ( (jpluse==0) .AND. (jmine==0) .AND. (jexp==1) ) THEN
                  se = 1
                  jpluse = 1
                  GOTO 200
               ELSE
               ENDIF
            ENDIF
            Icode = -999
            RETURN
!             IS THE CHARACTER A MINUS SIGN?
!             NOTE: IF THE FIELD IS FINISHED, A MINUS SIGN WILL CAUSE AN ERROR.
!	ANYTHING             ELSE IS AN ERROR.
         ELSEIF ( jchar==iminus ) THEN
                  sx = -1.0
                  jminf = 1
                  GOTO 200
                  se = -1
                  jmine = 1
                  GOTO 200
               ELSE
               ENDIF
            ENDIF
            Icode = -999
            RETURN
!             IS THE CHARACTER A DECIMAL POINT
!             NOTE: IF FIELD IS FINISHED, A DECIMAL POINT WILL CAUSE AN ERROR.
!	DECIMAL             POINTS ARE ONLY ALLOWED IN THE FRACTIONAL PART.
         ELSEIF ( jchar==idecpt ) THEN
               IF ( (jpoint==0) .AND. (jexp==0) ) THEN
                  jpoint = 1
                  jplusf = 1
                  jminf = 1
                  GOTO 200
               ENDIF
            ENDIF
            Icode = -999
            RETURN
!             IS THE CHARACTER AN 'E' OR A 'D'?
!             NOTE: IF THE FIELD IS FINISHED, AN EXPONENT WILL CAUSE AN ERROR.
!	ONLY             ONE EXPONENT MARK IS ALLOWED.
         ELSEIF ( (jchar/=iexp) .AND. (jchar/=iexpd) ) THEN
!             IS THE CHARACTER A VALID NUMERAL?
!             NOTE: IF THE FIELD IS FINISHED, A NUMERAL WILL CAUSE AN ERROR.
!	USE             THE LOOKUP-TABLE TO GET THE NUMERIC EQUIVALENT.
            DO jpl = 1 , 10
               IF ( jchar==itable(jpl) ) THEN
                  idigit = jtable(jpl)
                  IF ( jdone==1 ) THEN
                     EXIT
                  ENDIF
                  IF ( jexp==1 ) THEN
!             IF WE'RE DOING THE EXPONENTIAL PART, GET THE RUNNING EXPONENT.
                     ex = ex*10 + idigit
                     jdigit = 2
                     jpluse = 1
                     jmine = 1
                  ELSE
!             IF WE'RE DOING THE FRACTIONAL PART, GET THE RUNNING ANSWER.
                     x = x*10 + idigit
                     nex = nex + jpoint
                     jdigit = 1
                     jplusf = 1
                     jminf = 1
                  ENDIF
                  GOTO 200
               ENDIF
            ENDDO
            Icode = -999
            RETURN
         ELSE
               IF ( jexp==0 ) THEN
                  jexp = 1
                  jpoint = 1
                  jplusf = 1
                  jminf = 1
                  GOTO 200
               ENDIF
            ENDIF
            Icode = -999
            RETURN
         ENDIF
      ELSEIF ( (jplusf/=0) .OR. (jminf/=0) .OR. (jpluse/=0) .OR. (jmine/=0) .OR. (jpoint/=0) .OR.   &
             & (jexp/=0) .OR. (jdigit/=0) ) THEN
         jdone = 1
      ELSE
      ENDIF
!             SEE IF THE END-OF-THE-FIELD HAS BEEN REACHED?
 200  IF ( (Jstart+j-1)/=Jend ) THEN
         j = j + 1
         GOTO 100
!             END-OF-FIELD HAS BEEN REACHED.
!             NOTE: CHECK IF ENTIRE FIELD WAS COMPLETELY BLANK.
!	CHECK             IF ANY DIGITS AT ALL WERE ENCOUNTERED
!	CHECK             IF THE EXPONENTIAL PART HAD ANY DIGITS.
      ELSEIF ( (jplusf==0) .AND. (jminf==0) .AND. (jpluse==0) .AND. (jmine==0) .AND. (jpoint==0)    &
             & .AND. (jexp==0) .AND. (jdigit==0) ) THEN
!             HANDLE BLANK FIELD HERE.
         Icode = 0
         RETURN
      ELSEIF ( jdigit>=1 ) THEN
         IF ( (jexp/=1) .OR. (jdigit==2) ) THEN
!             WORK OUT NUMERICAL RESULT HERE
            Result = sx*FLOAT(x)*10.0**(se*ex-nex)
            Icode = 1
            GOTO 99999
         ENDIF
      ELSE
      ENDIF
      Icode = -999
      RETURN
99999 END SUBROUTINE READ2
[/cpp]
h_amini
Einsteiger
2.179Aufrufe
Quoting - bmchenry
enjoy!
brian
Appreciated very much. It is fairly similar to the subroutine I am writing.
Hamid
onkelhotte
2.179Aufrufe
Quoting - h.amini
Hamid
I havent looked through the whole code of bmhenry...
I think all you need is "index" and "adjustl". The following code is written in this quote, I havent tested it in IVF, but it should work with a few modifications...
myCode is your line " 1 45-47 350 "
[cpp]character*255 tempstring, tempstring2,tempstring3
integer(kind=4) arraysize, dummyInt1, dummyInt2, posDash, arrayCounter, i
integer(kind=4), allocatable:: intArray(:)
arraysize = 0
read(tempstring,'(a)') myCode
! removing first
tempstring = tempstring(index(tempstring,'')+1:)
tempstring = adjustl(tempstring)
read(tempstring2,'(a)') tempstring
! getting the arraysize
do while(tempstring(1) /= '')
! removing leading blanks
  read(tempstring3,'(a)') tempstring(:index(tempstring,' '))
  posDash = index(tempstring3,'-')
  if(posDash  == 0) then
    arraysize = arraysize + 1
  else
! reading start and endvalue (not sure if -1 is right...)
    read(dummyInt1,'(i)') tempstring3(:posDash-1)
    read(dummyInt2,'(i)') tempstring3(posDash:)
    arraysize = arraysize + (dummyInt2-dummyInt1+1)
  end if
! removing number(s)
  tempstring = tempstring(:index(tempstring,' '))
! remove leading blanks
end do
! filling the array
if (arraySize > 0) then
  allocate intArray(arraySize))
  arrayCounter = 1
  do while(tempstring2(1) /= '')
    read(tempstring3,'(a)') tempstring2(:index(tempstring2,' '))
      read(intArray(arrayCounter),'(i)') = tempstring2(:index(tempstring2,' '))
      arrayCounter = arrayCounter + 1
    else
      do i = dummyInt1,dummyInt2
        read(intArray(arrayCounter),'(i)') = i
      end do
    end if
    tempstring2 = tempstring(:index(tempstring2,' '))
    tempstring2 = adjustl(tempstring2)
  end do
end if
[/cpp]
Les_Neilson
Geschätzter Beitragender II
2.179Aufrufe
I didn't look closely but a couple of things caught my eye.
Minor points :
"" is "/" in the original
replace internal read for tempstring2 with
tempstring2 = tempstring.
(apart from being wrong way round) why not just
tempstring3 = adjustl(tempstring(:index(tempstring,' ')))
the adjustl above may not be needed as adjustl is done at end of the loop
The internal reads need swapping round e.g. :
should be
read(tempstring3(:posdash-1), '(i)' ) dummyInt1 ! format could be (*)
read(tempstring3(posDash+1:), '(i)' ) dummyInt2 ! Need to bypass thedash "-"
Les
h_amini
Einsteiger
2.179Aufrufe
Quoting - Les Neilson
Minor points :
should be
Les
Many thanks. You are right. The code needs modification. Please see post 6.
Hamid
h_amini
Einsteiger
2.179Aufrufe
Quoting - onkelhotte
Thank you very much for your kind consideration. It is possible not to have a blank character between the last number and the second "/". Also there are some data after the second slash, so I modified your code, but got a strange problem in getting the array size.
character*255 tempstring, tempstring1, tempstring2,tempstring3
character*255 tempstring4
character*255 dummyInt20
& arrayCounter, i
arraysize = 0
OPEN(unit = 2, file = 'zread.dat')
READ (UNIT = 2, FMT = "(a)") tempstring
! removing first /
tempstring = tempstring(index(tempstring,'/')+1:)
! removing last /
tempstring = tempstring(:index(tempstring,'/')-1)
do while(tempstring .NE. ' ')
read(tempstring,'(a)') tempstring3(:index(tempstring,' '))
PRINT*, 'tempstring3',tempstring3,'posDash',posDash
if(posDash .EQ. 0) then
else
tempstring3 = adjustl(tempstring3)
read(tempstring3(:posDash-1),'(i)') dummyInt1
PRINT*, 'dummyInt1',dummyInt1
10 read(tempstring3(posDash+1:),'(a)') tempstring4
20 PRINT*, 'tempstring4',tempstring4
30 read(tempstring3(posDash+1:),'(i)') dummyInt2
40 PRINT*, 'dummyInt2',dummyInt2
end if
tempstring = tempstring(index(tempstring,' '):)
end do
PRINT*, 'arraysize',arraysize
END
In reading a data file like / 12 30-132 33 45 / 3, the code cannot read the number after the dash (132). Using similar format it can be read with a string character (tempstring4), but not with the integer variable (dummyInt2). The error I get is:
forrtl: severe (64): input conversion error, unit -5, file Internal Formatted Re
Does anyone know what's wrong?
Many thanks
Hamid
onkelhotte
2.179Aufrufe
Your mistake is, that you want to store the character string "132 " in an integer variable. That causes your error.
You can do it that way:
30 read(tempstring3(posDash+1:index(tempstring,' ')),'(i)') dummyInt2
Markus
h_amini
Einsteiger
2.179Aufrufe
Markus
Many thanks Markus. You are absolutely right!
Hamid
Antworten
