I am going to initiate a dialog in a fortran windows program.
The dialog I want can be displayed on the discreen. But when I push the default bottoms (OK and Cancel) on it, the dialog can not disppear nomally, there comes a mistake. I don't know why.
Following is part of my routines:
lret = DlgInit(IDD_List, dlg)
ret = DlgModal( Dlg )
call DlgUninit(dlg)
BTW, this is not a main dialog, but a bottom absed one, which means that when I push the bottom on the main dialog, this dialog will appear.
Thank you.
call DlgUninit(dlg)
Thank you.
I may be wrong, but it sounds as if you're reusing the same Dlg variable for "parent" and "child" dialog, e.g.:
You must use different variables, i.e. declare another type(Dialog):: Dlg2 and use that.
Jugoslav
subroutine OnButtonClick(Dlg,id,iEvent) use dflogm type(Dialog):: dlg integer:: id,iEvent lret = DlgInit(IDD_List, dlg) ret = DlgModal( Dlg ) call DlgUninit(dlg)
Jugoslav
Jugoslav,
You are right.
Thank you, very much.
You are right.
