29391 Discussions
Problem related to double precision when using BCONF
yuezhanwei
I set the data kind to 8 under the project proterties ->Fortran -> Data.
I got the following error message when I use BCONF, which is the generic form.
CALL BCONF(FirmValue, 0, XLB, XUB, X, XGUESS=XGUESS,XSCALE=XSCALE, IPARAM=iparam, & RPARAM=rparam, FVALUE=F)
error #6285: There is no matching specific subroutine for this generic subroutine call. [BCONF]
When I use the specific form for double precision D_BCONF, I still got an error if I include IPARAM in the program
CALL D_BCONF(FirmValue, 0, XLB, XUB, X, XGUESS=XGUESS,XSCALE=XSCALE, IPARAM=iparam, & RPARAM=rparam, FVALUE=F)
error #6633: The type of the actual argument differs from the type of the dummy argument. [IPARAM]
What exactly I should use? Can someone help me with this problem? Thank you.
Best,
Vivian
Do not use D_BCONF - use the generic and fix the problem in calling the generic.
I would guess that "iparam" is not an integer array. What is its declaration?
yuezhanwei
Steve,
Thanks for your response. When I use the generic BCONF, I got the following error message.
I declare iparam as an integer. The complete code is the following. Can you tell me what the problem is? Thank you.
USE BCONF_INT
USE UMACH_INT
INCLUDE 'link_fnl_static.h'
!DEC$ OBJCOMMENT LIB:'libiomp5md.lib'
IMPLICIT NONE
INTEGER:: IPARAM(7), ITP, L, NOUT
REAL F, FSCALE, RPARAM(7), X(N), XGUESS(N), XLB(N), XSCALE(N), XUB(N), KLB, KUB
EXTERNAL:: FirmValue
XGUESS = (/b_p, 2.E0/)
XSCALE = (/1.E0,0.01E0/)
XLB = (/B_min, S_min/)
XUB = (/B_max, S_max/)
FSCALE = 1.E0
ITP = 0;
CALL DU4INF (IPARAM, RPARAM)
IPARAM(1) = 1;
RPARAM(1) = 1.0E-16
RPARAM(2) = 1.0E-16
RPARAM(6) = 1.0E8
CALL BCONF(FirmValue, 0, XLB, XUB, X, XGUESS=XGUESS,XSCALE=XSCALE, FVALUE=F, & IPARAM=iparam, RPARAM=rparam)
CALL ERSET (0, 1, 0)
Did you happen to also set the default integer kind to 8? If so, that's your problem.
yuezhanwei
You are exactly right! Thank you for your help.
