29285 Discussions
Problem to transfer "loadimage" to IFX
Kai8
My code using the ifort compiler works to display a Bitmap:
USE IFQWIN, ONLY: LOADIMAGE
i=LOADIMAGE ('Picture.bmp',1,1)
Once I switch to the ifx compiler I get the following fatal error on execution:
Program Exception 0x00007FF6390D2D82 in xxx.exe: 0xC0000005
andrew_4619
Ifx is 64 bit only. In 64 bit the return value of loadimage is a 64 bit address. My guess is that I is a 32 bit integer.
Kai8
I usually take the default integer, which is KIND=4 in my case.
Unfortunately it did not help to declare i with Kind=8. The same error occurs.
andrew_4619
And my second thought is the name you are passing is not null terminated pass 'name'//achar(0)
Kai8
I tried this, but no success. The same error occurs.
Meanwhile I found that this happened after I updated to the latest ifx version 2025.0.0. I can still run the code with an older ifx version. This happens on several projects where I use LOADIMAGE.
andrew_4619
I had a look at your original post. I now see you are using ifqwin loadimage not the SDK loadimage so my comments are not so relevant. Do you have a traceback to that specific line? Have you tried it in the debugger? The problem is not clear. Can you make a simple program with a few lines that reproduces this?
Kai8
Well, there is not very much to add to the above snipplet. To make sure, that the error is not provoked by any other parts of my original code, I tested the below program:
program Main
implicit none
INTEGER i
!---- Display Bitmap
i=LOADIMAGE ('ROSETem.BMP', 1, 1)
end program Main
The runtime result is:
If I switch from ifx back to ifort this code runs without problem.
The debugger stops on the line calling LOADIMAGE
andrew_4619
Well that is simple I cannot test myself as I am away but hopefully one of the intel people will pick that up
Kai8
Who can take care of this?
This error affects almost all of my programs and seems to be an issue within the compiler.
andrew_4619
I looked at you example in IFX 2025.0.0 and it does indeed crash as you say. I also looked at the interface in IFQWIN.f90 and I see no issue with  your call.  I agree it looks like a bug in IFX, hopefully Ron or Devorah will pick this up.
MANOLIS
Dear andrew_4619
The same problem with LOADIMAGE function in QWIN FORTRAN application, using IFX, happens with function SAVEIMAGE too.
So, please inform the developers of IFX 2025.0.0 to also take care of it.
Thank you
Manolis
taehunkim
If you change from x64 to win32 in configuration manager (MSVS), it works well.
Kai8
Dear Taehunkim
this is definitely no solution. I would not want to sacrifice computation efficiency just to be able to plot a bitmap in the pre-processing. Changing to Win32 brings along a whole bunch of other issues in my codes.
I hope you can update IFX soon.
BR
Kai
andrew_4619
      You cannot do a 32 bit build with IFX.
Devorah_H_Intel
@Kai8 and @MANOLIS, I have escalated this case to our compiler engineering. Thank you for your report.
(For future reference, reporting issues and bugs via the Online Service Center will expedite the process and, eventually, the fix. )
Devorah_H_Intel
The issue is fixed, and the fix will be available in the next 2025.1 ifx release.
