Problem with OpenMP loop and polymorphic object
Arash_Rasekh
I have a problem in my program when i compile it with /Qopenmp. At a random point, the following run-time error apeared:
"forrtl: severe (173): a pointer passed to DEALLOCATE points to an object that cannot be deallocated"
Here there is a simplified version of my code:
[fortran]
module ModuleVector
implicit none
integer, parameter :: wp = kind(1.0d0)
type,abstract :: TypeVectorBase
real(wp) :: x=0._wp
real(wp) :: y=0._wp
contains
procedure(interfaceVectorAssignment),deferred,private :: vectorAssignment
generic :: assignment(=) =>vectorAssignment
end type
type,extends(TypeVectorBase) :: TypeVector2d
contains
procedure,private :: vectorAssignment=>vectorAssignment2d
end type
abstract interface
subroutine interfaceVectorAssignment(vector1,vector2)
import :: TypeVectorBase
class(TypeVectorBase) ,intent(out) :: vector1
class(TypeVectorBase) ,intent(in) :: vector2
end subroutine interfaceVectorAssignment
end interface
! declerations
class(TypeVectorBase),allocatable :: baseVector
class(TypeVectorBase),allocatable :: testVector(:,:)
contains
subroutine vectorAssignment2d(vector1,vector2)
! 11/18/2012
class(TypeVector2d) ,intent(out) :: vector1
! body
vector1%x=vector2%x
vector1%y=vector2%y
end subroutine vectorAssignment2d
end module
module ModuleEquationOfState
! Created: 02/23/2013
use ModuleVector
implicit none
type,abstract :: TypeEquationOfStateBase
class(TypeVectorBase),allocatable :: rhoU
end type TypeEquationOfStateBase
type,extends(TypeEquationOfStateBase) :: TypeCaloricallyPrefectGas
end type TypeCaloricallyPrefectGas
! deceleartions
class(TypeEquationOfStateBase),allocatable :: equationOfState
!$OMP THREADPRIVATE(equationOfState)
end module ModuleEquationOfState
subroutine initiateCaloricallyPrefectGas(equation)
use ModuleEquationOfState
use ModuleVector
implicit none
! Created : 05/24/2013
!Arguments
class(TypeEquationOfStateBase),intent(inout) :: equation
! local variables
! body
allocate(equation%rhoU,source=baseVector)
end subroutine initiateCaloricallyPrefectGas
subroutine evaluateTimeStepSimple(blockNumber,ElementNumber)
! 05/27/2013
use ModuleVector
implicit none
!Arguments
integer,intent(in) :: blockNumber,ElementNumber
!Local variables
! Body
equationOfState%rhoU=testVector(blockNumber,ElementNumber)
end subroutine evaluateTimeStepSimple
subroutine runLowStorageRungeKutta()
!$ use omp_lib, only: OMP_GET_NUM_PROCS,omp_set_num_threads
!$ use ModuleVector
!$ use ModuleEquationOfState
implicit none
! local variables
integer :: m,i,j
!$ real(8) :: power
!$ integer :: numberOfThreads,numberOfProcessors
!$ power=0.75 !Conditional compilation
!$ numberOfProcessors= OMP_GET_NUM_PROCS() !Conditional compilation
!$ numberOfThreads= numberOfProcessors*power !Conditional compilation
!$ call omp_set_num_threads(numberOfThreads) !Conditional compilation
!$ call omp_set_nested(.true.)
!!$ call omp_set_dynamic(.true.)
do m=1,5
!$OMP PARALLEL DO SCHEDULE(DYNAMIC,1) DEFAULT(SHARED) COPYIN(equationOfState)
do i=1,10
!$OMP PARALLEL DO SCHEDULE(GUIDED) SHARED(i) DEFAULT(SHARED) COPYIN(equationOfState)
do j=1,15
!write(*,*), "Hello world." ! When this statement uncommented, issue doesn't occur.
call evaluateTimeStepSimple(i,j)
end do
!$OMP END PARALLEL DO
end do
end do
end subroutine runLowStorageRungeKutta
program testProgram
use ModuleVector
allocate(TypeVector2d::baseVector)
allocate(testVector(10,15),source=baseVector)
allocate(TypeCaloricallyPrefectGas:: equationOfState)
testVector.x=10._wp
testVector.y=20._wp
call initiateCaloricallyPrefectGas(equationOfState)
call runLowStorageRungeKutta()
end
[/fortran]
When i uncomment the write statement in runLowStorageRungeKutta subroutine, the program work without problem.
I use Intel Fortran 13.0.3615 and my project configuration is:
[xml]
<Configuration Name="Debug|x64">
<Tool Name="VFFortranCompilerTool" AdditionalOptions="&#xA;" SuppressStartupBanner="true" DebugInformationFormat="debugEnabled" Optimization="optimizeDisabled" Preprocess="preprocessYes" AdditionalIncludeDirectories="&quot;C:\Program Files (x86)\Intel\Composer XE 2013\mkl\include&quot;;&quot;C:\Program Files (x86)\Intel\Composer XE 2013\compiler\include&quot;" OpenMP="OpenMPParallelCode" F2003Semantics="true" Diagnostics="diagnosticsShowAll" DebugParameter="debugParameterAll" WarnInterfaces="true" Traceback="true" BoundsCheck="true" RuntimeLibrary="rtMultiThreadedDebug" Interfaces="true"/>
<Tool Name="VFLinkerTool" LinkIncremental="linkIncrementalNo" SuppressStartupBanner="true" AdditionalLibraryDirectories="&quot;C:\Program Files (x86)\Intel\Composer XE 2013\mkl\lib\intel64&quot;" GenerateDebugInformation="true" GenerateMapFile="true" SubSystem="subSystemConsole" AdditionalDependencies="mkl_lapack95_ilp64.lib mkl_intel_ilp64.lib mkl_intel_thread.lib mkl_core.lib libiomp5md.lib"/>
<Tool Name="VFResourceCompilerTool"/>
<Tool Name="VFMidlTool" SuppressStartupBanner="true" TargetEnvironment="midlTargetAMD64"/>
<Tool Name="VFCustomBuildTool"/>
<Tool Name="VFPreLinkEventTool"/>
<Tool Name="VFPreBuildEventTool"/>
<Tool Name="VFPostBuildEventTool"/>
<Tool Name="VFManifestTool" SuppressStartupBanner="true"/></Configuration>
[/xml]
Best regards, Arash.
Arash_Rasekh
The problem apear in vectorAssignment2d subroutine which called in nested parallel loop by calling evaluateTimeStepSimple.
Arash.
Arash_Rasekh
After changing the intent of vector1 from intent(in) to intent(inout), the problem solved but new issues apeard.
Here there is the new code which new function added to it:
[fortran]
module ModuleVector
implicit none
real(wp) :: x=0._wp
real(wp) :: y=0._wp
contains
procedure(interfaceVectorVectorRealVectorOperator),deferred,private :: vectorVectorRealAdditionVectorResult
generic,public :: add=>vectorVectorRealAdditionVectorResult
end type
contains
procedure,private :: vectorVectorRealAdditionVectorResult =>vectorVectorRealAdditionVectorResult2d
end type
abstract interface
class(TypeVectorBase) ,intent(inout) :: vector1
function interfaceVectorVectorRealVectorOperator(vector1,vector2) result(vector3)
import :: TypeVectorBase,wp
class(TypeVectorBase),intent(in) :: vector1
real(wp),intent(in) :: vector2(:)
!class(TypeVectorBase),intent(inout) :: vector1 ! changed due to OMP bugs.
!real(wp),intent(inout) :: vector2(:)! changed due to OMP bugs.
class(TypeVectorBase),allocatable:: vector3
end function interfaceVectorVectorRealVectorOperator
end interface
! declerations
contains
! 11/18/2012
class(TypeVector2d) ,intent(inout) :: vector1
! body
vector1%x=vector2%x
vector1%y=vector2%y
function vectorVectorRealAdditionVectorResult2d(vector1,vector2) result(vector3)
!12/15/2012
! arguments
class(TypeVector2d),intent(in) :: vector1
!!$OMP THREADPRIVATE(vector3)
! body
allocate(TypeVector2d :: vector3)
vector3.x=vector1.x+vector2(1)
vector3.y=vector1.y+vector2(2)
return
end function vectorVectorRealAdditionVectorResult2d
end module
use ModuleVector
implicit none
integer,allocatable :: a
! deceleartions
use ModuleVector
implicit none
!Arguments
! local variables
! body
allocate(equation%a)
! 05/27/2013
use ModuleVector
implicit none
!Arguments
!Local variables
! Body
!$ use ModuleVector
implicit none
! local variables
integer :: m,i,j
!$ real(8) :: power
do m=1,1
do i=1,10
do j=1,10
testVector(i,j)=equationOfState%rhoU%add([1._wp,1._wp])
end do
!!$omp barrier
end do
end do
program testProgram
use ModuleVector
allocate(testVector(50,50),source=baseVector)
testVector.x=10._wp
testVector.y=20._wp
end
[/fortran]
The new problem occur due to allocation and deallocation of vector3 in function vectorVectorRealAdditionVectorResult2d by multiple threads at same time. Because the vector3 is the return value of the function, i cannot define it as a threadprivate variable. (it need save attribute which cannot use for result of function)
I want to know is there anyway to define the result value of a function as a private variable for each thread (in dynamic extent of a parallel region)?
P.S: I have to much functions where their results are polymorphic variables or allocatable arrays. So i cannot change them to subroutine in order to prevent ussing temporary variables.(i.e result of function)
Steven_L_Intel1
You do have an error in your program which the compiler warns me about - you call initiateCaloricallyPrefectGas from the main program, and this routine has an implicit interface (it isn't in a module.) However, the routine has a polymorphic argument and the standard requires an explicit interface in this case.  You should put those routines in a module as well.
What you're doing should work - it is almost certainly a compiler bug that it doesn't. I will take a look at the revised program and see what is going on.
Arash_Rasekh
Thank you Steve.
In my orginal program explicit interfaces are included, But here for simplification i removed them from sample code.
Steven_L_Intel1
Ok. They don't affect the symptoms, but I wanted to mention it.
Out of curiosity, why did you use OMP !$ to conditionally USE the modules in runLowStorageRungeKutta? The program won't compile then if you don't enable OpenMP.
Arash_Rasekh
I'm working on a project which have serial and parallel cores. The cores are FORTRAN DLL and handled by a C# user interface. I use conditional compilation just for safety, because the cores built by a set of shared sources. (i.e. the serial and parallel cores sources are almost same and just their project configurations are different)
Steven_L_Intel1
I have escalated the problem to developers as issue DPD200246974.
I asked about the conditional compilation for the USE lines specifically, as without them the source would not compile at all - at least not in this version. Maybe your actual code looks different.
Arash_Rasekh
Ah, sorry, you are right.
In the original code they must compiled just for parallel core. i forget to remove their conditional compilation on the sample code.
In OpenMP Application Program Interface Version3.1 specification document, the data-sharing attributes of result values for FORTRAN doesn't mentioned. Are they encountered as local variables - and thus they are shared variables- or they are private to each thread?
Steven_L_Intel1
They should be the same as any local variable in the function and private to each call of the routine in each thread.
Arash_Rasekh
Thank you Steve for your help.
IanH
The OpenMP 4.0 spec says "polymorphic things aren't supported".  Is this really a bug proper, or just a reflection of that spec?
Steven_L_Intel1
I made the type non-polymorphic and still saw a problem, but I'll take another look. You could be right.
IanH
If your answer was "sod the spec - we've taken the initiative to extend our implementation of OpenMP to cover other bits of F2003 in what we think is a sensible fashion" I'd be very happy.
Steven_L_Intel1
My opinion is that either it should work, or the compiler should complain if such is not supported.
