Problem with RenameFileQQ
davidgraham
I am using RenameFileQQ to rename a directory.
I have noticed that the documentation only says it renames a file.
I have used the code previously to rename a directory and it works.
use ifport,only:RenameFileQQ
logical*4 lret
lret=RenameFileQQ("c:\Grade\data\TEST","c:\Grade\data\1234")
In the previous version that worked, I was using a BrowseForFolder routine but in the new code that doesn't work I'm using a BrowseForFile routine.
The BrowseForFolder routine was from a file CommonDlgXtras.f90 which I got from the forum from John Termine.
The BrowseForFile routine uses GetOpenFileName
The error I get after RenameFileeQQ using GetLastErrorQQ is error 13 ERR$ACCES - Permission denied. The file's permission setting does not allow the specified access
Do you have any suggestions why this is not working?
Kevin_D_Intel
The documentation does say it renames a file but it is renaming a directory for me with our latest PSXE 2017 Update 1. I need to inquire if that is expected/supported.
What version of our compiler are you using?
Did you verify the appropriate permissions exist on all components of the path and the directory that is getting renamed?
IanH
My guess... GetOpenFileName is changing the current directory to be the same as the directory you are trying to rename.
davidgraham
Kevin,
The compiler is Intel(R) Visual Fortran Compiler XE 12.1.4.325
Ian,
Your guess was correct - I reset the current directory and it worked.
Thank you
Kevin_D_Intel
Thank you for the version id. Glad you resolved it. I'm told RENAMEFILEQQ will work for folders/directories too but it is odd seeing MAKEDIRQQ, DELDIRQQ, CHANGEDIRQQ but no "RENAMEDIRQQ". I will follow up w/the documentation writers about adding clarification.
