Problem with an array
Anton_Helm
Hallo,
I have a problem with an array. When I want to change his value (for example: ind(1) = 1) then i get the following message:
[bash]forrtl: severe (174): SIGSEGV, segmentation fault occurred
Image              PC                Routine            Line        Source
testarray          00000000004011F3  Unknown               Unknown  Unknown
testarray          00000000004010F8  Unknown               Unknown  Unknown
testarray          0000000000401075  Unknown               Unknown  Unknown
testarray          0000000000400F9C  Unknown               Unknown  Unknown
libc.so.6          00007FAD1A46D5A6  Unknown               Unknown  Unknown
testarray          0000000000400E99  Unknown               Unknown  Unknown[/bash]
In the attachment is the full code. It's only a example of my problem. It's not possibile to send you the right code. in the file "track.f" at line 9 is my problem. When I don't write something in the array, I don't get into trouble.
Thx
array.zip
afellow
You may need to first allocate the array before you write anything into it.
Try add:
allocate(ind(nsize))
before you call your track function.
afellow
Try add:
Anton_Helm
Thanks. Founded too, but you was faster.
