Trying to make a linked list of an abstract type, the compiler reported
(1) Feature not implement and
(2) catastrophic error: **Internal compiler error: internal abort**.
The second error message suggested that the code be sent in, so here it is.
This used 11.1, 64-bit version on Linux.
badCrash.f90(54): error #5415: Feature not yet implemented: SOURCE=polymorphic_expression
allocate(elem%object,source=obj)
badCrash.f90(79): catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
surface => getNextFromSurfaceListIterator(set)
compilation aborted for badCrash.f90 (code 3)
If there are ways around these problems, I would love to hear about them.
[fortran]module badCrash_module
implicit none
integer, parameter :: dp = selected_real_kind(14)
type, public :: surface_type
character(12) :: name
real(dp), dimension(:), allocatable :: a
contains
procedure :: displaySurface
end type surface_type
type, private :: element
class (surface_type), allocatable :: object
type (element), pointer :: next
end type
type, public :: surfaceList_type
private
integer :: number ! total number of objects in the set
type (element), pointer :: first ! first object in the list
type (element), pointer :: last ! last object in the list
type (element), pointer :: getter ! used for the iterator
end type
contains
subroutine displaySurface(this)
implicit none
class (surface_type), intent(in) :: this
write(*,10)this%name,size(this%a)
10 format(1x,'Surface ',A,' with length of a=',I0)
end subroutine
subroutine initializeSurfaceList(set)
type (surfaceList_type), intent(inout) :: set
set%number = 0
nullify(set%first)
nullify(set%last)
nullify(set%getter)
end subroutine initializeSurfaceList
subroutine addToSurfaceList(set, obj)
implicit none
class (surface_type) :: obj
type (element), pointer :: elem
allocate(elem)
! error #5415: Feature not yet implemented: SOURCE=polymorphic_expression
nullify(elem%next)
if ( set%number > 0 ) then
set%last%next => elem
set%last => elem
set%number = set%number + 1
else
set%first => elem
set%last => elem
set%number = 1
end if
end subroutine addToSurfaceList
subroutine displaySurfaceList(set)
implicit none
class (surface_type), pointer :: surface
set%getter => set%first
do
if(.not. associated(set%getter))exit
! catastrophic error:
! **Internal compiler error: internal abort** Please report this error
call surface%displaySurface()
end do
end subroutine displaySurfaceList
function getNextFromSurfaceListIterator(set) result (obj)
class (surface_type), pointer :: obj
obj => set%getter%object
if(associated(set%getter%next))then
set%getter => set%getter%next
else
nullify(set%getter)
end if
end function getNextFromSurfaceListIterator
end module badCrash_module
[/fortran] badCrash.f90(54): error #5415: Feature not yet implemented: SOURCE=polymorphic_expression
