Problem with an old fortran program on a new machine
gerges__joseph
Hello ,
I'm a noob in fortran
I used to use an old fortran program on a unix machine (5 Years ago)
I'm tryig to reuse now on a windows machine. I'm trying to compile it in vain (usign ifort .in an intel compiler using : ifort mkmodel.f)
I know i should use fft libraries but i don't know how.
This is the program i'm trying to compile.
Thanks in advance
Steve_Lionel
Never mind - I see what you did in your earlier upload.
You have this in routine FF_PARAM:
C       FORCE_FIELD
        FF_file(1:20) = '/mnt/c/bin/FF'
        FF_file(21:25) = FF
        FF_file(26:26) = '/'
        FF_file(27:31) = INTRA_PROP
        FF_file(32:35) = '.tab'
That first assignment will insert 7 blanks after the 'FF', since the value is 13 characters and the substring is 20.
GVautier
New Contributor III
Effectively
FF_file='/mnt/c/bin/FF'//trim(FF)//'/'//trim(INTRA_PROP)//'.tab'
Another solution but less safe because it fails if the resulting string is longer than FF_file length
write(FF_file,"('/mnt/c/bin/FF',A,'/',A,'.tab')")trim(FF),trim(NTRA_PROP)
