29649 Discussions
Problem with initialization of derived type variable
johnyb_
In the following example code, the behaviour changes if the value of the parameter clen is more than 7196
[fortran]program test
    integer, parameter :: clen = 7197
    TYPE T_BLOCK
        character(len=clen)    :: ch
    end type T_BLOCK
    type(T_BLOCK) :: b2
    type(T_BLOCK) :: b1 = T_BLOCK( '' )
    b2                  = T_BLOCK( '' )
    print *, "clen          :", clen
    print *, "len_trim b1%ch:", len_trim(b1%ch)
    print *, "len_trim b2%ch:", len_trim(b2%ch)
    if (b1%ch /= '') then
        print *, "b1 ch is not empty"
    else
        print *, "b1 ch is empty"
    endif
    if (b2%ch /= '') then
        print *, "b2 ch is not empty"
    else
        print *, "b2 ch is empty"
    endif
end program[/fortran]
with the value of 7196 i get the following:
[plain] clen          :        7196
 len_trim b1%ch:           0
 len_trim b2%ch:           0
 b1 ch is empty
 b2 ch is empty
[/plain]
with the value of 7197 i get this:
[plain]clen          :        7197
len_trim b1%ch:        7197
len_trim b2%ch:           0
b1 ch is not empty
b2 ch is empty[/plain]
I compile without any options:
C:\\TEMP>ifort test.f90
Intel Visual Fortran Compiler XE for applications running on IA-32, Version 12.1.1.258 Build 20111011
Copyright (C) 1985-2011 Intel Corporation. All rights reserved.
Microsoft Incremental Linker Version 10.00.40219.01
Copyright (C) Microsoft Corporation. All rights reserved.
-out:test.exe
-subsystem:console
test.obj
In the compiler documentation I read about a limit for character and Hollerith constants of 7198. However, in the above example, if I set clen to 50000 the behaviour is still the same as for 7197 (b1 not empty, b2 empty).
I can not understand if this is a compiler limit, compiler bug or a missunderstanding on my behalf.
I'd be grateful for any explanation
Johny
I'd say that this is a compiler bug. It is in fact setting b1%ch to all nulls, or not setting it at all (more likely). I will report this to the developers - thanks for the nice test case. I would expect that, given this bug, any value above 7196 would fail in the same way. Issue ID is DPD200176374.
johnyb_
Yes, any value above 7196 fails.
This happened in a piece of code that is generated where several character components of a derived type have a length of > 32000 characters. We have recently acquired licenses for Intel Fortran and I am porting our code, which worked nicely except for this small trouble.
I can work around the bug by changing the tests generated to something like if ( .not. b1%ch > '')
It only happens with derived types, simple character variables work correctly:
    integer, parameter :: clen = 50000
    character(len=clen)    :: ch1 = ''
    character(len=clen)    :: ch2
    ch2 = ''
    print *, "ch1:", len_trim(ch1)
    print *, "ch2:", len_trim(ch2)
    if (ch1 /= '') then
        print *, "ch1 is not empty"
    else
        print *, "ch1 is empty"
    endif
    if (ch2 /= '') then
        print *, "ch2 is not empty"
    else
        print *, "ch2 is empty"
    endif
and the result:
[plain] clen          : 50000
 ch1: 0
 ch2: 0
 ch1 ch is empty
 ch2 ch is empty[/plain]
Yes, I expect this is related to the structure constructor, since this implicitly creates a value as long as the character component when used in an initialization expression. In the executable code, the components are assigned individually.
We've found and fixed the bug here - it was indeed restricted to structure constructors when the character component was longer than 7196. I expect the fix to appear in the first update to the 15.0 compiler.
