Problem with libimf.so
joeanddeborah
Hello, For some reason, ifort cannot find "libimf.so" even though I have confirmed it is in /lib I get the same error message whether I'm logged in as a user or root. Has anyone else had this problem?
Thanks Joe
TimP
More details? For example, are you trying to mix architectures between your build and the library present on LD_LIBRARY_PATH ?
If 'ldd yourexecutable' doesn't show the dependency on libimf, then I suspect it's a bug, which may be corrected by adding -limf to your compile/link options. I believe ifort should always automatically include -limf, but I have seen it fail to do so.
Message Edited by tim18 on 02-10-2006 01:55 PM
joeanddeborah
Ahhh, I think you're on to something. I have KDevelop 3.3.1 installed and it requires the following line in my .bash_profile:
export LD_LIBRARY_PATH=$QTDIR/lib:$KEDIR/lib:$LD_LIBRARY_PATH
and, of course, ifortvars.sh has
if [ -z "${LD_LIBRARY_PATH}" ]
then
LD_LIBRARY_PATH="/opt/intel/fc/9.0/lib"; export LD_LIBRARY_PATH
else
LD_LIBRARY_PATH="/opt/intel/fc/9.0/lib:$LD_LIBRARY_PATH"; export LD_LIBRARY_PATH
fi
I am brand new to Linux, so forgive me if this is obvious. But, is there a conflict here that I need to clean up?
Joe
TimP
You need the LD_LIBRARY_PATH set in accordance with that ifortvars.sh if you are using the 32-bit or ia64 compiler. If you are using the em64t compiler, you need it set in accordance with /opt/intel/fce/9.0/bin/ifortvars.sh.
joeanddeborah
Okay, so how exactly do I fix the problem? All I am atempting to do is compile and make the int_sin.f90 example to confirm proper ifort installation.
joeanddeborah
Never mind, I figured it out. If I put the lines in my .bashrc script instead of my .bash_profile script, it works just fine. Thanks, Tim, for your help! Linux has a very steep learning curve, I guess. At least, it does for me :-)
