Problem with new Fortran
garraleta_fortran
The version of FORTRAN and Visual Studio is:
Intel® FORTRAN Compiler 2025.0.4 [Intel(R) 64]
Microsoft Visual Studio Community 2022 (64-bit) - Current Version 17.13.3
There is no problem with the old version of FORTRAN.
Intel(R) Visual FORTRAN Package ID: w_fcompxe_2013.2.149
Microsoft Visual Studio Team System 2008 Architecture Edition 1899-270-2717477-60709
I attach two ZIP files with the projects of both solutions
Devorah_H_Intel
with upcoming 2025.1 ifx:
garraleta_fortran
Debug problems with new FORTRAN
JohnNichols
Honored Contributor I
module datos
    TYPE Vector
    integer(4) :: X
    integer(4) :: Y
    end type vector
    end module datos
    program mainer
    USE DATOS
USE ISO_FORTRAN_ENV
IMPLICIT NONE
TYPE(VECTOR) :: V
OPEN(UNIT=1,FILE='RES.TXT')
WRITE(1,FMT='(A)')COMPILER_VERSION()
V.X=100
V.Y=200
WRITE(1,*)'VP',V.X,V.Y
CALL SUB1(V)
CALL SUB2(V)
CALL SUB3(V)
CLOSE(UNIT=1)
END
SUBROUTINE SUB1(V1)
USE DATOS
IMPLICIT NONE
TYPE(VECTOR) :: V1
WRITE(1,*)'V1',&
V1.X,V1.Y
RETURN
END
SUBROUTINE SUB3(V3)
USE DATOS
IMPLICIT NONE
TYPE(VECTOR) :: V3
WRITE(1,*)'V3',&
V3.X,V3.Y
RETURN
END
SUBROUTINE SUB2(V2)
USE DATOS
IMPLICIT NONE
TYPE(VECTOR) :: V2
WRITE(1,*)'V2',&
V2.X,V2.Y
RETURN
END
Your Fortran is spread across five modules, you left one out, I found it in the bmp.
Here it is as one program.
It is running on a COREi7, latest Windows Preview, latest VS 2022 Preview and the latest update to the 2025.2.1 release.  You cannot be more up to date than this.
The shots of the debug screen as I step through your program in one file.  Notice that you only see the debug for the current subroutine.
Just as expected.
Your picture shows the open files and the files that do not have focus show
XX shows the notification that the subroutine does not have focus so it is not updated as you step through V3.F90 , NN is normal as you have focus on V3.F90 according to the break point cursor.  I can see all of your values as required, this is absolutely all you need.
Once you have left V1 then any good garbage collector in other languages could clean it up.
garraleta_fortran
If the main program, mudule and subroutines are in the same file, it works fine.
Attached video
JohnNichols
I understand what you are saying and I watched the video, but exactly what do you want the program to do in debugging.
You need to provide an explanation.
garraleta_fortran
I should do this.
Like Intel(R) Visual Fortran Compiler XE 13.1
garraleta_fortran
With th new version 2025.3.0.324 work !!!! OK ¡¡¡¡
garraleta_fortran
"WHEN WILL VERSION 2025.1 ifx BE AVAILABLE?
Devorah_H_Intel
2025.1 is coming out within a week.
JohnNichols
Please do not use bitmaps, bmp will not upload and I need to change them to png.
