29640 Discussions
Problem with omp simd loop, ifx 2025.2
puipp
I experience the following problem with ifx (IFX) 2025.2.0 20250605
forrtl: severe (408): fort: (3): Subscript #2 of the array RES has value 0 which is less than the lower bound of 1
 which I could reproduce with the following test code
subroutine problem()
  integer, parameter :: np = 1000
  integer :: i, n, l, m, k, k_periodic, nk_stripped, j, lb, ub
  integer :: res(np, 1:4)
  nk_stripped = 4
  lb=-1
  ub=4
  !$omp parallel default(none) firstprivate(lb,ub) shared(nk_stripped, res) private(i, k, k_periodic)
  do n = 1,2
  do m = 1,10
  do l = 1,10
  do k = lb, ub
    !$omp do simd
    do i = 1, np
      k_periodic = modulo(k-1, nk_stripped) + 1
      if (k_periodic < 1 .or. k_periodic > nk_stripped) then
        print *, "ERROR: k_periodic out of bounds: ", k_periodic, " at k=", k, " i=", i
      end if
      res(i, k_periodic) = k
    end do
    !$omp end do simd
  end do
  end do
  end do
  end do
  !$omp end parallel
end subroutine
 produces
ERROR: k_periodic out of bounds:            0  at k=           0  i=         744
while I would expect k_periodic above to always be within 1 and 4.
I only encounter this with ifx in debug mode, not with gcc or ifort, and only when build in debug mode using the following flags
-g -fPIC -fpp -g -no-wrap-margin -traceback -fstack-security-check -fpe0 -O0 -warn all -check all,noarg_temp_created
 -debug inline-debug-info -ftrapv -Rno-debug-disables-optimization -fiopenmp
removing the simd from the code avoids the problem. Is this expected behaviour?
jimdempseyatthecove
    !$omp do simd
    do i = 1, np
Implies (requires?) that an array in the body of the do loop is referenced in a manner suitable for simd instructions
The body of the loop contains:
Which might confuse the code generation for
I suggest you relocate that (and the error test) code to the do k loop and see what happens:
  do n = 1,2
  do m = 1,10
  do l = 1,10
  do k = lb, ub
    end if
    !$omp do simd
    do i = 1, np
    end do
    !$omp end do simd
  end do
  end do
  end do
  end do
  !$omp end parallel
BTW, I suggest you use:
k_periodic = modulo(k-lb, nk_stripped) + 1
as it is clearer as to the intent.
Jim Dempsey
jimdempseyatthecove
    !$omp do simd
    do i = 1, np
  do n = 1,2
  do m = 1,10
  do l = 1,10
  do k = lb, ub
    end if
    !$omp do simd
    do i = 1, np
    end do
    !$omp end do simd
  end do
  end do
  end do
  end do
  !$omp end parallel
Jim Dempsey
puipp
Thank you, I confirm that this works.
