I see different results for the attached code depending on the used compiler flags. Notice that the code uses a recursive elemental subroutine, which I understand is allowed in f2015, but not allowed by the previous standards, hence the compiler flag -recursive .
Apart from -recursive, I think the code should work without depending on other compiler flags.
The expected result is printing -2 10.
$ ifort -recursive ifb.f90 -o ifb
$ ./ifb
[nothing is printed]
$ ifort -recursive -assume realloc_lhs ifb.f90 -o ifb
$ ./ifb
-2 10 [the correct result]
$ ifort -recursive -assume realloc_lhs -standard-semantics ifb.f90 -o ifb
$ ./ifb
1986356271 1937010735 [arbitrary values]
I am using ifort Version 15.0 Build 20150407.
module m1 ! Define an abstract type, a container and the corresponding assignment implicit none type, abstract :: a_abs end type a_abs type, extends(a_abs) :: t_cnt class(a_abs), allocatable :: f end type t_cnt interface assignment(=) module procedure to_cnt end interface contains elemental subroutine to_cnt(y,x) class(a_abs), intent(in) :: x type(t_cnt), intent(out) :: y select type(x) type is(t_cnt) y = x%f ! equivalent to "call to_cnt( y , x%f )" class default allocate( y%f , source=x ) end select end subroutine to_cnt end module m1 !------------------------ module m2 ! Define a specific type and an operation use m1, only: a_abs implicit none type, extends(a_abs) :: t_a integer, allocatable :: i(:) end type t_a contains elemental function add(x,y) result(z) class(t_a), intent(in) :: x, y type(t_a) :: z z%i = x%i + y%i end function add end module m2 !------------------------ program p use m1 use m2 implicit none type(t_a) :: a, b type(t_cnt) :: cnt allocate( a%i(2) , b%i(2) ) a%i = (/ 0 , 6 /) b%i = (/ -2 , 4 /) cnt = add( a , b ) select type( f => cnt%f ) type is(t_a) write(*,*) f%i class default write(*,*) "class default" end select end program p
The first result is understandable. The last is not, but curiously it reproduces for me only on Linux, not Windows. Very interesting. I found that if you add -assume noprotect_parens, you get the correct result. (This is one of the things that -standard-semantics turns on.) Escalated as DPD200374568.
With -stand set, ifort 16.0 rejects "recursive elemental subroutine"
-recursive doesn't appear to make a difference.
-Qprotect-parens doesn't pose a problem, although assume:protect_parens does produce run-time failure.
Steve Lionel (Intel) wrote:
The first result is understandable. The last is not [...]
Steve, thank you. Concerning the first result however, I don't see why -assume realloc_lhs should make a difference, since all the allocations should take place in the source allocation.
OK, I assume that whatever choice in terms of extensions is fine; still it would be nice to be able to override some settings of -stand with an additional, more specific option like -recursive ...
You need -assume realloc_lhs (or -standard-semantics which includes it) because your assignment to z%i depends on it.
Eventually we will support the F2015 relaxed restriction on RECURSIVE ELEMENTAL.
Oh, yes, sorry, I added the two allocations in the main program and forgot this one; adding allocate(z%i(size(x%i))) removes the need for realloc_lhs, so the problem here is completely independent from -assume realloc_lhs .
Marco
