29487 Discussions
Problem with shape of arrays using reallocation feature with TRANSPOSE(RESHAPE(..))
bpichon
Dear Fortran !
Here a possible bug with intel compilers (both Windows and Linux OS)
I don't see previous post for this problem but sorry in the converse case.
It involves :
   1)   TRANSPOSE(RESHAPE(...))             (yes, why not !)
   2)   Fortran 2003/2008 (re)allocatation feature
What do you think about this ?
Bernard
With ifort 14.0.0074.11 on windows 8 (via visual studio 2012)
 V(6)=[1,2,3,4,5,6]
 1 2 3 4 5 6
  D = RESHAPE(V,[3,2])
 1 2 3 4 5 6
  E = TRANSPOSE( RESHAPE(V,[3,2]) ) in one step :
            WRONG (E has not the right shape ...)
 3 2   |   2 3
 1 4 -858993460 2 5 -858993460
  F = TRANSPOSE(D)  with  D = RESHAPE(V,[3,2])  in two steps : Ok
 2 3
 1 4 2 5 3 6
  G = RESHAPE( V, Shape=[2,3] , Order=[2,1] ) in one step
                       with keyword order of RESHAPE : Ok
 2 3
 1 4 2 5 3 6
With ifort 14.0.0 (20130728)  on Linux (ifort with -assume realloc !!)
  V(6)=[1,2,3,4,5,6]
           1           2           3           4           5           6
           1           2           3           4           5           6
           3           2   |             2           3
           1           4          18           2           5           0
           2           3
           1           4           2           5           3           6
                       with keyworf order of RESHAPE : Ok
           2           3
           1           4           2           5           3           6
Please reattach your test case - something went wrong.
bpichon
I try again as an attached file
bpichon
I don't know if i succeed
Here the text of the test :
program test
!ifort test.f90 -assume realloc_lhs
integer, Dimension(:,:), Allocatable :: C, D, E, F, G
integer, Dimension(6) :: V = [1,2,3,4,5,6]
Write(*,*) 'V(6)=[1,2,3,4,5,6]'
Write(*,*) V
Write(*,*)
Write(*,*) " D = RESHAPE(V,[3,2]) "
Write(*,*) D
Write(*,*)
Write(*,*) " E = TRANSPOSE( RESHAPE(V,[3,2]) ) in one step : "
Write(*,*) " WRONG (E has not the right shape ...) "
Write(*,*) SHAPE(E), ' | ', SHAPE( TRANSPOSE( RESHAPE(V,[3,2]) ) ) ! very curious
Write(*,*) E
Write(*,*)
F = TRANSPOSE(D)
Write(*,*) " F = TRANSPOSE(D) with D = RESHAPE(V,[3,2]) in two steps : Ok "
Write(*,*) SHAPE(F)
Write(*,*) F
Write(*,*)
Write(*,*) " G = RESHAPE( V, Shape=[2,3] , Order=[2,1] ) in one step "
Write(*,*) " with keyword order of RESHAPE : Ok "
Write(*,*) SHAPE(G)
Write(*,*) G
Write(*,*)
end program test
m_sulc
Ah, yes, with ifort version 14.0.0.080 Build 20130728, the statement
[fortran]
[/fortran]
produces incorrect results (moreover dependent on the level of optimization)...
I can reproduce this in 14.0, but not in our next-release development stream. I have asked the developers to see if an explicit fix for this was made and if it could be added to 14.0. Issue ID is DPD200250177.
The developers identified the fix and said it will go into Update 2, planned for January.
