Problems compiling very old library
Stephen_Painchaud
I am trying to compile a FORTRAN library from circa 1985. A common error message I get for the debug version is
Error: The type of the actual argument differs from the type of the dummy argument.
This is a common theme, where a subroutine is called with a real argument, but it is used as an integer.
Is there some way I can turn off this check in the debug version? The release version compiles fine. I will need a debug version at some point.
Steven_L_Intel1
Right click on the project, select Properties, Fortran, Diagnostics. Turn off "Generate interface blocks" and "Check routine interfaces". Be very careful about such mismatches - they can create serious problems.
