Problems in linking to MKL
newguy
This message has been moved to the Intel Math Kernel Library forum which launched on Dec. 18, 2003.
cp_jain
Hi
AFAIK just linking lapack32.so is not enough. You should
also link libmkl_def.so or libmkl_p4.so
Please read MKL's documentation to get more information on this.
Regarding
usr/lib/crt1.o:In function '_start':***
/usr/lib/crt1.o(.text+0x18): unidentified reference to 'main'
error - you will get this error if you try to create an executable with file without the main function.
Use -c option to just compile the file (without main function).
cp
newguy
Thanks my Desi friend, it works now.
