Problems reading data from file
alphajet
Actually I know this is supposed to be quite simple, but I've been stuggling with this for hours !
I simply need to write an array of data to file, so that I would read it somewhere else in a different computer, so I tried the procedure on a given array I have,I firstly used the following code:
[bash]open(unit=2, file='a.dat', status='replace') do i=1,NZ write(2,*), MatrixCSR(i) enddo do i=1,NZ read(2,*), MatrixCSR2(i) enddo [/bash]But then I got the fort(24) error concerning the end of file during read, so I modified the code to be:
[bash]open(unit=2, file='a.dat', status='replace') do i=1,NZ write(2,*), MatrixCSR(i) enddo do i=1,NZ read(2,*,END=1), MatrixCSR2(i) enddo 1 CONTINUE[/bash]Now it's going without errors, but the destination array "MatrixCSR2" just includes zeros, so no data was imported at all, what's wrong with this simple snippet ?!
TimP
You would need to endfile and rewind unit 2 (if you are an f66 fan) or close and reopen the file between writing and reading.
TimP
alphajet
Sir, you're totally right ! and I must use status='old' during the open line intended for read, I don't even need to check for the end of file (END=1 statement)
[bash]open(unit=2, file='a.dat', status='replace') do i=1,NZ write(2,*), MatrixCSR(i) enddo close(2) open(unit=2, file='a.dat', status='old') do i=1,NZ read(2,*), MatrixCSR2(i) enddo
[/bash]
TimP
You're welcome. Primary reason for turning computer on holiday, in case anyone is intereseted, replaying tour de france, magnifique!
