29653 Discussions
Reference material for coding Windows application in FORTRAN
OP1
New Contributor III
Besides the examples that ship with the compiler, is there a good modern starting point/reference document for programming Windows applications (SDI or MDI) in Fortran?
Thanks in advance,
Olivier
I would suggest Compaq Visual Fortran: A Guide to Creating Windows Applications by Norman Lawrence. Pretty much all of it is still applicable to Intel Visual Fortran.
JVanB
Valued Contributor II
That's a good book, and the examples can be found with enhancements (but not bug fixes) in the companion web site. A major issue about the book is that it uses hard-wired KIND numbers everywhere, thus breakingin 64-bit environments. It would be nice if some of the fans of the book rewrote the examples with appropriate named constants for these KIND numbers, elimination of unnecessary extensions, and bug fixes. I've got a chunk modified in this fashion, for example, and a few more readers could likely come up with a more or less complete set if our activities were coordinated in some fashion.
OP1
New Contributor III
Thanks for the suggestion - this is was I had been told as well; I was just hoping for a more recent/modern presentation, especially since IVF has gone through significant changes and upgrades since then.
Olivier
Yes, but the fundamentals of Windows API programming have not changed and we've tried to maintain compatibility with the older techniques. Indeed, the major issue to look for is the need to use kind values such as HANDLE or PVOID where Lawrence's book assumed 32-bits always.
