Problems starting IDB on Ubuntu
gdaturi
Hello -
I've been using the Fortran compiler environment for a few weeks now without any problems. Recently I have started getting problems starting the java debugger GUI, and I think it may be because of suggested synaptic updates or a java update. I have tried re-installing the debugger, made sure I am setting the JRE correctly, and even rolled back a couple updates. The debugger works in command line "idbc" mode. These are the errors I get. Any help is appreciated - I am getting no where fast!
WARNING: ASSERTION "(pdomDocument) != ((void*)0)" FAILED AT ./src/Common/Memento/XMLMemento.cpp,line 135
Stack Backtrace follows:
/home/ocean18/intel/Compiler/11.1/046/idb/gui/intel64/libOsgJni.so [0x7f3eee16c96e]
/home/ocean18/intel/Compiler/11.1/046/idb/gui/intel64/libGuiMgr.so((null)+0x1cc) [0x7f3eed2beafc]
/home/ocean18/intel/Compiler/11.1/046/idb/gui/intel64/libGuiMgr.so((null)+0x2f6) [0x7f3eed53c122]
/home/ocean18/intel/Compiler/11.1/046/idb/gui/intel64/libGuiMgr.so((null)+0x380) [0x7f3eed4fbf52]
/home/ocean18/intel/Compiler/11.1/046/idb/gui/intel64/libGuiMgr.so((null)+0xd) [0x7f3eed4fc9fb]
/home/ocean18/intel/Compiler/11.1/046/idb/gui/intel64/libOsgJni.so(Java_com_intel_debugger_ui_jni_NativeCallsProxy_native_1initialize+0x8b) [0x7f3eee16cca1]
[0x7f3f7a20ff50]
WARNING: ASSERTION "(m_pPersistentSettings) != ((void*)0)" FAILED AT ./src/WindowMgr/WindowMgr.cpp,line 234
/home/ocean18/intel/Compiler/11.1/046/idb/gui/intel64/libGuiMgr.so((null)+0x1fd5) [0x7f3eed53de01]
[0x7f3f7a20ff50]
ReactionMgr: Error in XML Structure - handler "DataChangeNtfHandler" is not supported by provider "WindowMgr"
ReactionMgr: Error in XML Structure - handler "DebuggeeEventNtfHandler" is not supported by provider "WindowMgr"
[Fatal Error] :-1:-1: Premature end of file.
TimP
Does 'java -version' show the Sun 1.6 64-bit jre running? Does Ubuntu have their own version of it, in order to compensate for the non-standard paths?
pacobraxe
Quoting - tim18
I have the same problem. The result of java -version is:
java version "1.6.0_0"
OpenJDK Runtime Environment (IcedTea6 1.4.1) (6b14-1.4.1-0ubuntu11)
OpenJDK 64-Bit Server VM (build 14.0-b08, mixed mode)
I have to say that, during the installation, a compatibility check warning appeared: the program did not find java 1.5. I did not care because I thought that version 1.6 would be OK... In fact, the installation reported no errors.
Paco Braxe
TimP
Not obvious distinctions. As Ron mentioned below, the Iced Tea designation is a warning flag.
I have installed the 11.1.056 intel64 several times, all with some version of java 1.6, which installed without complaint on the previous ifort version. Some of them gave a complaint from the installer, and require me to accept installation with missing prerequisites. In any case, only the functioning of the GUI idb would be in doubt, but I believe it is still working OK.
Ron_Green
It appears Ubuntu installs a non-Sun JRE/JDK, the OpenJDK IcedTea6. Intel does not test against this nor do we support it.
I would recommend installing the Sun JRE, from here http://java.com/en/download/manual.jsp
ron
TimP
ron
Before installing Sun JRE, you may have to remove OpenJDK, or at least, if /usr/bin/java is a symlink, remove that, so that the Sun JRE can install normally as the one visible to the Intel installer.
pacobraxe
Quoting - tim18
the problem did not disappeared install java from SUN. The problem I got was:
java.lang.UnsatisfiedLinkError: /opt/intel/Compiler/11.1/056/idb/gui/intel64/libOsgJni.so: libstdc++.so.5: shared object file cannot be opened
A smart guy told me that he had the same error and that it was related to the use of versions 32 bit or 64 bit of this library. Anyway, I could solve my problem installing:
apt-get install libstdc++5
Paco
TimP
Yes, most up to date distros make the (backward compatibility) libstdc++5 libraries separate install options (and the name for it is not uniform), as has been mentioned in several posts on this forum.
gdaturi
Hi All,
Thanks so much for the help, but it still doesn't appear to be working! The IDB used to work fine, and still doesn't.
I just updated to the newest compiler and IDB - when I updated there was a warning about an incorrect JRE existing! I believe I have a compatible JRE. When I type java - version, I get the following:
java version "1.6.0_16"
Java SE Runtime Environment (build 1.6.0_16-b01)
Java HotSpot 64-Bit Server VM (build 14.2-b01, mixed mode)
I've also gone to the synaptic manager and made sure I have the latest lbstdc++5 installed.
Help! Thanks!
TimP
Quoting - gdaturi
I upgraded to that version of jre and re-installed ifort 11.1.056 (on RH5.2). It gave me the message about no compatible JRE, so I "accepted missing prerequisites," then checked that my test application builds and runs correctly under idb GUI. According to my tests, jre 1.6.0_13 (on RH5.3) and 1.6.0_16 (current) (on RH5.2) x86_64 versions give the ifort installer warning, but work OK. 1.6.0_14 gave no complaint with ifort installer.
ohinai
This is a bit old, but I hope it might help someone else out there. I know someone who had the exact same problem. The issue was that there were temporary .idb*** files created in the home directory that were causing this error message. Check your home directory for stray files and delete them, it might fix the problem.
